PP or not?
PP or not?
Big decision ahead. I will never track the car, boulevard cruising and short trips only. I am looking at a GT with most options I just can't decide on the PP or not. The ride might be too firm, fuel mileage not as good....dunno.
IMHO if you're never going to the track and just looking for a car to cruise in, I would spend the extra on the pp. I just got a 2015 GT premium without any additional options. So far I'm loving it.
As lame as it sounds I got my 2014 with the package mostly because of the wheels/tires/brakes... And now I feel like I want aftermarket wheels and tires anyway... Go with what makes sense... And it's not like a non pp will be bad on a track or spirited driving either...
I'd do it for the 6 piston Brembos and 15" rotors alone. I'd change everything else anyways, but you can recoup a lot of the cost by selling the stock wheels and suspension if you ever change them...
I got the PP on mine. I don't plan on swapping out my stock 19's. The PP might also give you other stuff you may not see like better handling components (strut/sway bar) like others said. Do what makes sense and feels right in your gut.
it was a no brainer for me. I didn't like the base model package.
I am not going to order a car without a spare. You can order 19" wheels (648) and get a spare. Why not the 19" (67G)? I don't think it can be that hard. If it is the Brembo brakes perhaps the front wheel would work on the rear. If not Ford could make a wheel that would fit both could they not?
Would you share the part number of the spare wheel you purchased? Will it fit both front and rear?
Don't waist your money on PP if you're not going to use it. Base brakes on the 15s are better than before. The only place you'd notice a Torsen, big brakes or the improved cooling is on the track.
I take my 2014 GT Track Pack to road courses. If I didn't it would be too stiff and jerky for the street. Plus with 3.73s I'd think the gears are too short for city driving. Don't get me wrong, I LOVE my TP, but only because I get to really push it at the track every summer.
Don't waist your money on PP if you're not going to use it. Base brakes on the 15s are better than before. The only place you'd notice a Torsen, big brakes or the improved cooling is on the track. I take my 2014 GT Track Pack to road courses. If I didn't it would be too stiff and jerky for the street. Plus with 3.73s I'd think the gears are too short for city driving. Don't get me wrong, I LOVE my TP, but only because I get to really push it at the track every summer.
I have read several articles on the 2015, and one indicated the PP was great if you were tracking it, But otherwise it might be to much for just street use. I would suggest you try and find one to test drive before you order or buy. Also test a normal GT and compare the two for the driving you will be doing. I usually test drive a route that I use every day to judge the cars handling, suspension and braking.
The part number for the spare is : FR3Z*1K007*C (This is a kit consisting of the tire/wheel, jack and mounting hardware to install it in the trunk well.) Cost was $255.00
I have read several articles on the 2015, and one indicated the PP was great if you were tracking it, But otherwise it might be to much for just street use. I would suggest you try and find one to test drive before you order or buy. Also test a normal GT and compare the two for the driving you will be doing. I usually test drive a route that I use every day to judge the cars handling, suspension and braking. The part number for the spare is : FR3Z*1K007*C (This is a kit consisting of the tire/wheel, jack and mounting hardware to install it in the trunk well.) Cost was $255.00
I agree with laserred38 the factory has never put a suspension on that was too stiff only too soft and under dampened. That said the PP is a terrific street suspension finally they put some damping in the shocks how long they will last is anybodies guess but the do work well when new. I for one wouldn't live with the stock GT suspension the old track pack was almost as bad they don't hold a candle to the PP. I don't like the factory wheels not on any budget car like the Mustang. They are always too heavy and the PP wheels are no exception 33 pounds each is silly my 20x10.5 TSW weighed 24.5 pounds each. Massive chassis stiffening, stiffer bushings, Torsen differential [don't like the 3.73], bigger brakes front and rear, different sway bars, a dark colored dash instead of the hideous silver, better aero splitter, etc, the PP package is a steal.
