Sponsored by:
Sponsored by: CARiD
MyColor Not adjustable In Daytime?
Old Dec 10, 2014 | 10:49 AM
v8ter's Avatar
Wheres the light sensor to turn the ambient lighting on and change gauge color whenever I want to
Old Dec 10, 2014 | 10:54 AM
JeffreyDJ's Avatar
I think you simply need to turn your lights on manually
Old Dec 10, 2014 | 11:05 AM
SD CALSPCL's Avatar
Lights do not have to be on. However, mine are set to automatic. My Color is controlled from the center screen. I just changed mine to Red. You can also adjust the intensity and dim them.
Old Dec 10, 2014 | 11:26 AM
JeffreyDJ's Avatar
In the daylight it doesn't allow you to change it is what he is saying. To "trick it" you simply turn the lights on (though I base this completely on another thread where someone else had the same issue. I changed mine in a parking garage during the day).
Old Dec 10, 2014 | 12:16 PM
v8ter's Avatar
I tried turning the lights on but it still doesent let me change ambient or gauge color and when I back out of the garage the gauge turns white again
Old Dec 10, 2014 | 12:24 PM
CCTking's Avatar
I think the light sensor is right in the center of the upper dash right infront of the windshield. My buddy covered his with black electrical tape
Old Dec 10, 2014 | 01:43 PM
Fear's Avatar
For 2005-2009s... lights have to be on to adjust/view the ambient "my color" lighting. Without the headlights being on, your gauge(s) will always be white
Old Dec 10, 2014 | 02:18 PM
SD CALSPCL's Avatar
I did change mine parked in my garage, which may account for my not seeing the lights come on, since they are on auto, I was busy looking at the screen.
I just went through the E-Manual and cannot find any reference to My Color. I will check my paper one later.
Correct me if I am wrong, but I believe the dash display defaults to white back lighting during the day. My 2011 GT/CS did this. My 2013 SHO also was backlighted by white light during the day. I just tried mine and the dash was red, until the lights went off and the instruments then turned white as I drove away in the daylight.
Old Dec 10, 2014 | 03:19 PM
Getportfolio's Avatar
Yea defaults to white.
I played with mine the other day only to get frustrated and realize that I needed the lights on!
Old Dec 11, 2014 | 10:25 AM
FordService's Avatar
Yes, v8ter. The info provided by the other members is correct. In order for them to work the headlights must be on and it does not function in the daytime. Without the headlights being on, your gauges will be white.
Deysha
Old Dec 11, 2014 | 12:01 PM
HizliBullet's Avatar
to change mycolor during the day, automatic headlamp setting isnt enough, make sure u take a hat or something to cover up the light sensor up infront of the dash then u could go into the settings
Old Dec 11, 2014 | 01:38 PM
v8ter's Avatar
This is what I need,because when outside,even if I have the lights on it doesent let me change color on the gauge or ambient
mx5jhb
Sep 30, 2015 04:44 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
colt breaker
Sep 24, 2015 08:20 AM
y5e06
Sep 21, 2015 08:05 AM
Sep 16, 2015 06:44 PM
