2015 Spy Shots
Old 8/1/12, 09:19 PM
908ssp's Avatar
Originally Posted by cinque35
They look way better than that retro crap we got stuck with.
Old 8/1/12, 10:05 PM
Automagically's Avatar
I think they look good, just think its funny that it looks very 80s and all these Mustang fans DO NOT want a Fox body return. Even though I know it won't be one.
Old 8/2/12, 01:14 AM
watchdevil's Avatar
i like the gauges, coolant temp under the tach, fuel under the speedo..
I would not read much into this as this is just a functional mule with a few Fusion parts stuck in the current Mustang interior for testing upgraded sytems that will eventually be tailored, styled and integrated into the actual 2015 design..
Old 8/2/12, 05:18 AM
rarecat's Avatar
I doubt it's a 2.0 Ecoboost, the full duals in the suspension shots says V6 or V8
Old 8/2/12, 05:29 AM
jmoss's Avatar
Oh us that IRS I see? >
Old 8/2/12, 05:37 AM
SVTCobraR315's Avatar
Not a fan of the interior. Looks like it should be in the F150 or explorer. But a 6500 redline... Seems like the ecoboost to me.
Old 8/2/12, 08:09 AM
cinque35's Avatar
I can't believe how much negative rear camber they're tuning in. It looks so funny on an S197 to see negative rear camber - looks like the axle is broken hahaha
didn't notice till you said something.. it does look funny
Old 8/2/12, 08:34 AM
Cybermagi's Avatar
More spy shots from the 2015 Test Mule
http://www.insideline.com/ford/musta...d-mustang.html
Old 8/2/12, 08:37 AM
Bow Chica Bow Wow
TMS Staff
burningman's Avatar
love that IRS....not so sure about that center stack though
Cybermagi's Avatar
opss didn't see the earlier thread..
Old 8/2/12, 08:55 AM
Liquid's Avatar
Confirmed: 2015 Mustang will be hellaflush
Old 8/2/12, 09:09 AM
rhumb's Avatar
I'd withhold final judgement of the interior just yet as it is a clumsy mixture of a few new bits essentially duct-taped to the stripped out shell of the current interior, so it would be hard to judge how the final design will turn out and cohere.
That all said, obviously a very different and far more current center stack, if awkwardly placed in the prototype. Might get some vague indication of where the final design might be going though, and the shape of the edges of the center stack might also give some indication of the shaping of the rest of the dash, but hard to say though (will it actually be much more angled or fairly upright as shown?). I'm a little surprised the screen isn't a bit bigger, more fully filling the area between all the buttons.
What about the steering wheel? Might that be some indicatation or even close to what the actual wheel will be? My thought would be yes as they will need to integrate the steering wheel controls with the center stack electronics. Also, if not, then why not go the easier expedient of using the current wheel along with the rest of the interior shell?
What about the tach? That seems different than the current one, less retro in the font to be sure.
Overall, expect a far more modern interior, if still with some Mustang DNA, than the current rendition.
Then the other two pics under the rear. Quite obviously an IRS, which is a big "duh" at this point. Some indications of the final design/geometery, which kind of reminds me of either an E46 or even E90 BMW, which ought not to be surprising as the 3 Series / M3 is an obvious benchmark. Much aluminum though there does seem to be a trailing/diagonal link in stamped steel perhaps, but hard to say/see, really.
Old 8/2/12, 10:26 AM
AWmustang's Avatar
I know when Car and Driver tried to put the engine from a Mazdaspeed 3 into a Mazda 5, the engine would not start unless its computer was tied to the original gauges from the Mazdaspeed 3. If that is a similar situation here they may be testing out a different engine and instead of going through a lot of effort to rewrite the code to make it work with the Mustang gauges they just screwed in a set of gauges already setup to work with the engine. And therefore these gauges have absolutely nothing to do with what will eventually go into the new Mustang. Considering how integrated Ford's new cars are, it could be the same case with the steering wheel and the center stack.
Old 8/2/12, 10:36 AM
RandyW's Avatar
While this center stack shown probably isn't the one that will end up being used, I do hope that the navigation screen is mounted high, like in this mule. You have to take your eyes fairly far from the road when the nav screen is mounted lower.
Old 8/2/12, 11:14 AM
Topnotch's Avatar
Steering Wheel has possibilities...
Old 8/2/12, 11:23 AM
Liquid's Avatar
I'm really hoping for a flat bottom
Old 8/2/12, 11:30 AM
This!
I wouldn't pay any mind to that interior. It looks like pieces from the for parts bin. You can see cutouts where they just screwed in buttons. Look at the kick panel trim on the passenger side. It lines up with nothing.
Old 8/2/12, 12:18 PM
908ssp's Avatar
That wheel looks good, better if the shinny stuff was black. I like the shape of the gauge cluster just make the tach in the middle and the digital speedometer off to one side.
Old 8/2/12, 12:49 PM
PTRocks's Avatar
It's been mentioned elsewhere that the interior bits that have been tacked on come from the base 2013 Fusion S, including the headlight switch. As such, I wouldn't read anything into the 6500 RPM redline, that is most likely a carryover detail. (EDIT) Inside Line believes the gauges are from the 2013 Escape
It should also be noted that the underbody pictures are NOT from the silver car, they are a reposting of the black car's pics that came out a couple of weeks back. Note the tires are Goodyears, and not the Pirelli's seen on the silver car.
I hope the AC is still working in some form, it must suck to have to drive that mule in the heat of the day without any dash vents.
Old 8/2/12, 02:16 PM
  #40
Twin Turbo's Avatar
Good to see some more spyshots
Personally, I very much doubt that will be the look of the '15 Mustang interior......far too early for Ford to let slip what that's going to look like. I suspect it's just easier for them to lift the Fusion centre stack/dials and we can assume the '15 will use all of that tech, just in a different package.
I also hope the steering wheel maintains a round boss. For me, all sports cars/sports saloons should have a round boss, so an evolution of the current wheel would work for me.
Quick Reply: 2015 Spy Shots
