Sponsored by:
Sponsored by: CARiD
2015 Mustang GT MRT Resonator Delete H-Pipe Install Video
Old Feb 16, 2015 | 10:39 AM
Steve@CJPP's Avatar
Former Vendor
Mustang Racing Technologies HPMR1 Mustang Delete H-Pipe GT 15
Today we are installing MRT's stainless steel resonator delete H-Pipe fitting all 2015 GT Mustangs. One of the most common complaints of the new S550 is the resonator box that crosses the exhausts. This box is very heavy and very restrictive. The simplest solution has been getting an aftermarket cat-back system, but this can be rather costly. Now thanks to MRT you can delete the resonator without having to replace the entire exhaust.
Available only at CJ Pony Parts, Mustang Racing Technologies, aka MRT, has engineered this Resonator Delete H-Pipe that easily replaces that bulky and restrictive OE Resonator. Manufactured completely out of CNC mandrel bent 304 Stainless Steel tubing, this H-Pipe will bolt-in place once two simple cuts have been made and the OEM segment is then unbolted and removed. The new H-Pipe will reuse the two factory clamps found on front and MRT will supply two new clamps to use on the rear section after the applicable cuts have been made.
Installation is pretty simple, remove the factory exhaust, cut off the factory resonator box and clamp on the new h-pipe, no welding required. The whole process can be don in about an hour in your garage or driveway and the results are amazing. As soon as you fire up the engine, even with the factory mufflers, your Mustang will sound much louder and more aggressive, like the muscle car that it is.
After installation your Mustang will be ready to hit the road, no tune is required with MRT's Resonator Delete H-Pipe.
For more H-Pipes available at CJ Pony Parts check out:
Mustang H-Pipes | CJ Pony Parts
For more MRT parts available at CJ Pony Parts check out:
MRT | Mustang Racing Technologies | CJ Pony Parts
Old Feb 16, 2015 | 05:18 PM
MuddyLX's Avatar
Did you happen to weight the resonator to see how much weight it actually removes?
Old Feb 16, 2015 | 10:31 PM
boomer46's Avatar
I read on another forum they weigh about 35 lbs. Can't remember where or what forum I saw it on, otherwise I would have cut & pasted it for you. No way to verify that tho.
Old Feb 17, 2015 | 04:09 AM
Spiker52's Avatar
Hmmmm, like the sound! I see my first mod here when I get my GT.
Don
Old Feb 17, 2015 | 07:33 AM
Steve@CJPP's Avatar
Former Vendor
Bill says
Resonator comes in at 23 lbs & the H pipe is 8 lbs
Old Feb 17, 2015 | 08:10 PM
5.M0NSTER's Avatar
Great upgrade to make the 2015 sound like the 2011-14
rcarrilloGTP
Sep 3, 2015 09:27 AM
iiizman
Jul 20, 2015 11:33 AM
NacsMXer
Jul 18, 2015 07:45 PM
Jul 17, 2015 05:40 PM
JonathonK
Jul 15, 2015 07:53 PM
