-   Past Rumor Archive (https://themustangsource.com/forums/f805/)
-   -   2013 MY refresh (https://themustangsource.com/forums/f805/2013-my-refresh-491232/)
dmhines Apr 27, 2011 12:51 PM
No GT500 rear Spoiler that I can see ..
Twin Turbo Apr 27, 2011 01:07 PM
Thanks TN....nice find :-)
OK, a game of spot the difference. Most obvious is the smaller lower grille, smaller lower fogs (with possible slot for LED DRLs below), different vent in the hood......
http://autocarsnews.info/wp-content/...er-Picture.jpg
http://blogs.insideline.com/straight...efresh-f34.jpg
Overboost Apr 27, 2011 01:27 PM
I'm thinking this is a GT mule. The hood doesn't show enough air extraction compared to the current GT500, and an educated guess would think with a new blower and larger motor on tap, they wouldn't close the hood up as much.
Comparing that picture to the other spy shots listed in that link, the upper and lower grille openings are smaller than the GT500. They are similar in shape, however.
The SVT PP wheels may be used right now because FRPP makes them in a 19x9 size, which will likely be used again in some form, and going this route would keep potential new wheel designs under wraps.
Boomer Apr 27, 2011 01:40 PM
Regardless, you're starting to see some of the changes.
Front end being functional, where we'll start to see more changes in the less functional, more cosmetic stuff to come later.
xlover Apr 27, 2011 01:41 PM
they might have put the wrap over the extractors, if this is a GT mule then they must be using GT500 elements for confusions sake. I could possibly see this being the new lower bumper but the final car having a grill and hood more like the current GT. Still i cant see the "update" for 2013 being giving the GT a knockoff GT500 fascia and hood. i would hope ford shows a bit more imagination than that. not that i dont love the look of the GT500 but they need to be differentiated
Adam Apr 27, 2011 01:52 PM
I say it's a GT500.
Boomer Apr 27, 2011 01:55 PM
Merged...
Automagically Apr 27, 2011 02:12 PM
Whatever it is. Look closely. It's got a hood mocked after the GT500 as well as a smaller GT500 grille with GT Driving Lights (Blackouts), but the bumper cover is a modified V6 Bumper with LED strips is what that looks like where the below Fog Lights location are.
xlover Apr 27, 2011 02:20 PM
ha its probably a suspension mule and they put a mess of different parts on it for fun so they can watch us on the boards endlessly debate what it is.. i do see 9 guests viewing this thread at time of positing
Thomas S Apr 27, 2011 02:54 PM
I think it's definitely a GT500. They aren't going to change the GTs to a GT500 front end, that would be stupid. I think those slots below the lower fogs are for brake cooling ducts.
I'd like to see someone that's good with photoshop clean it up a little and make the camo body color.
Overboost Apr 27, 2011 02:57 PM
We need pictures of the rear and interior to really know. This picture is fairly old, we haven't had snow on the ground in MI for about 3 weeks now.
Automagically Apr 27, 2011 03:28 PM
I'm going with a negative on the brake cooling ducts. If that were the case why would you have a strip with perforated holes in it over a small slit indention in the bumper cover are? Maybe it could be but I just don't think it's the case. We've seen Ford tooling around with LED strips before.
BlueBossS197 Apr 27, 2011 04:49 PM
Instead of put LED strips as those daytime running lights, just use factory projector lamps for the fogs with built in halos to use as running lights instead. LED strips do not fit on the mustang, unless it were to be yellow LED strips for the turn signals in the headlight housing.
2010MustangGT Apr 27, 2011 08:48 PM
http://mustangsdaily.com/blog/wp-con...ng-bullitt.jpg
Maybe?
http://www.topspeed.com/cars/car-new...-ar106886.html
Based on pure speculation, the new Bullitt will likely make its appearance as a limited edition trim package on the 2013 Mustang GT Premium, costing just a bit more than the California Special. Like the Bullitts of yesteryear, the 2013 Bullitt should be available only in its signature Dark Highland Green and black.
Orrr... Mach 1?
http://www.stangtv.com/wp-content/bl...03/mach1-1.jpg
SynisterGT Apr 27, 2011 08:56 PM
I would rather seen a mach 1 bc they did the buillet in 08-09.
Big Vito Apr 27, 2011 08:58 PM
Boss 351?
Overboost Apr 27, 2011 09:58 PM
Why does everyone think this is another SE?
Big Vito Apr 27, 2011 10:06 PM
Is the Gt500 a SE?
Hawaii 5.0 Apr 27, 2011 10:09 PM
I dont think the GT500 is an SE, but maybe this is a mule with several diff parts just to make us forum junkies spend hours of our lives arguing about details. Or it very well could be a new SE. Only thing i have to say is, time will tell
Red Jay Apr 27, 2011 10:19 PM
wasnt there like an turbo'd stang a few months ago that was red and had those same wheels?? had the Boss gauges too, and i think a visible intercooler.... what if this is that Mustang?
