(Post 6913084)
Wow thank you! I don't think it's supposed to be a drain hole. I don't think the water is supposed to get into that spot in the first place!
Okay, it has rained hard, and not holding water at this time... We will see .
Originally Posted by soundman2033
(Post 6913382)
(Post 6913382)
Deysha |
Originally Posted by dave07
(Post 6913081)
I finally got around to trying to find this drain hole. I wasn't able to find a drain hole per say (it might be the drain hole but doesn't seem like it to me). But through some finagling with my finger i was able to get the water to drain! I ended up cutting out about an inch or so of foam to help the water drain out in the future.
A word of caution, this doesn't seem to me like a drain hole in my opinion. I was able to stick my finger down there and it honestly feels like a gap between the sheet metal. It does drain about 90% of the water though. If you are unhappy I guess you can buy some spray foam or something and fill the "drain" back in. I'm personally happy with this fix as my dealer is totally inept at fixing this problem. Besides its 100% reversible if you don't like it. |
(Post 6736478)
I took this to the dealer and they think it is fuel sloshing around in the tank. That's total BS. I showed them the photos and they still wont believe me. Drove the car away from the dealer with the sloshing sound still there. Whats worse is when the water freezes in the quarter panel and you can hear the ice banging around against the panels. It's loud. So frustrated right now. I'm curious to see what Ford is going to do. I'm in contact with the customer service manager in my area thanks to Deysha.
Originally Posted by SeanLB
(Post 6926800)
I'm having the same issue on my 2014 convertible. This is my first Ford and I was so pumped, but an unresponsive dealership has me very concerned. I cleaned the grommets in the doors the first time it happened, but now it's the rear quarters retaining water. Cmon man...it's a 2014. This shouldn't be happening already.
Welcome to the forum! My name is Deysha with Ford Service. You are always welcome to bring your vehicle in to different Ford Dealer for a second opinion. Also, I壇 like to get this escalated for you. Please PM me with your VIN, dealer you池e bringing it in to, mileage, full name, and best daytime number. I値l loop in the customer service manager for your area. Deysha |
Private message sent. Thanks!
Originally Posted by FordService
(Post 6926822)
Hello SeanLB,
(Post 6926800)
You most likely have another clogged grommet in rear quarter. Good luck with Ford fixing it. You will need it! ;) |
Any idea where those grommets are? Thanks for the reply, and we are already off to a rough start with the dealership.
(Post 6926967)
I think the convertibles are supposed to drain water through that area.
(Post 6926968)
(Post 6926965)
Deysha |
Well, add me to the list. 2014 base convertible. Heavy rain this week, drove about 60 miles in it last night, and got soaked passenger rear floor boards. I hear the sloshing, and the dripping in front of the wright rear wheel is right on point. I'm not super mechanical, so Ill be going to the local dealer this week. It will be my second visit to them, the first wasn't very successful regarding the rear defroster, but I don't see much choice. Wish me luck!
I don't know if anyone is still reading this, but I will add my experience to the list. Like so many others, I was basically told by the dealer it was the drain under the hood running back, and that he did find water in the rear quarter panel. He said that water was probably coming from the window, and that he opened up the drain and it would be fine. Then I get in the car and nudge the brakes. Guess what, water is still 'a sloshin. Called him back out to sit in the car and hear it, and surprise surprise, he cant hear a thing. I don't know how that's possible since it sounds like someone shaking a 5 gallon bucket of water. Finally he admits he hears something, but he says that its the- get this- the shocks making that sloshing sound, and its normal. The icing on the cake is a half hour later after getting back to work, water is still dripping from the rocker panels. I give up, this dealer failed to help with a bad rear defroster and has now failed on this. I PROMISE anyone who is reading this, I will never buy another Ford as long as I live. The car looks and drives OK, but the quality is sub par and the service is a joke. I could handle the poor quality, or the poor service, but living with both is unacceptable. I'm done. :banghead:
Water sloshing sound from passenger rear quarter panel
I hear you on the Ford service and quality. Wish they could step it up because they could have a great product if it wasn't for the lack luster service and poor quality. Chalk me up in the I'm done with Ford column too. |
(Post 6938676)
I don't know if anyone is still reading this, but I will add my experience to the list. Like so many others, I was basically told by the dealer it was the drain under the hood running back, and that he did find water in the rear quarter panel. He said that water was probably coming from the window, and that he opened up the drain and it would be fine. Then I get in the car and nudge the brakes. Guess what, water is still 'a sloshin. Called him back out to sit in the car and hear it, and surprise surprise, he cant hear a thing. I don't know how that's possible since it sounds like someone shaking a 5 gallon bucket of water. ...
Welcome to the forum. My name is Deysha with Ford Service. As dave07 mentioned, I知 happy to get this escalated for you. Please, PM me with your VIN, dealer, mileage, full name, and best daytime number. I値l get the customer service manager for your area involved.
(Post 6938681)
Ask for Deysha to get this escalated. I believe for the convertibles there should be some sort of drain located below the rear quarter window. Chances are you just have a plugged drain. This is not normal for coupes though. ...
Deysha |
ADD ME TOO THE LIST!!
I am having the identical issue since the last rainstorm we had here in FL. Have an appt with the dealer. Would be great if Deysha could escalate me as well.
(Post 6938816)
Hello Patrick Harlow,
Welcome to the forum. My name is Deysha with Ford Service. As dave07 mentioned, I知 happy to get this escalated for you. Please, PM me with your VIN, dealer, mileage, full name, and best daytime number. I値l get the customer service manager for your area involved. Thank you for the mention, dave07!! Deysha Please add me to list |
Originally Posted by CVilla12GT
(Post 6938840)
(Post 6938854)
Deysha |
(Post 6938676)
I'm with you guys on the terrible quality and service. I can understand cars will have problems, but if a good company takes care of their customers by fixing the problems not giving them the runaround. I'm having the same service issues with my rotting hood and paint bubbling trunk lid. As a customer I shouldn't have to jump through so many hoops to get factory defects properly corrected. And these aren't minor issues like a radio button fell off or my review mirror is loose, my hood is ROTTING at less than one year old and my trunk lid is already starting to shed paint - and this car sits in a garage 99% of the time and only comes out on nice days. |
