Transmission slipping?
I gassed it like normal as a light turned green but I went n turned n the next thing i know, my car starts to shake violently while no acceleration. I then decided to stop on the side of the road. Got out looked underneath to make sure nothing was dragging, nothing. got back in n then started it and continued on. No problems to my destination, which was an hour. It seemed to have happened slightly later eve. It seemed sluggish so i proceeded slowly the rest of the eve. Today it seemed ok. It was the first bitter cold the other day. Do u think i should get it looked at?
2012 gt - auto.
2012 gt - auto.
It seemed like no response while it shook as i gassed it. Other ppl seemed to notice it behind me they backed off of me to let me over. Ok i will take it in. I told a mech i met he said the samething, take it in. I hope i wont make them mad if i bring it n they say "i dont see nothing wrong". Conclusion jumping i know.
Thanks[cross fingers]
I gassed it like normal as a light turned green but I went n turned n the next thing i know, my car starts to shake violently while no acceleration. I then decided to stop on the side of the road. Got out looked underneath to make sure nothing was dragging, nothing. got back in n then started it and continued on. Do u think i should get it looked at?
2012 gt - auto.
2012 gt - auto.
I also recommend you bring your vehicle in to your Ford dealer for diagnosis. Then, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Deysha
They said no errors came up. So it musta been just a freak thing. Man, i feel dumb asking them and nothing is found. Thanks all for the help n suggestions. If it comes up again its going back.
If you have a problem it would be shake all the time. The TCS will make the car shake or shutter if you put your foot in it. I turn off AdvanceTrac off unless it's raining.
Sounds like you need to find an empty parking lot away from everything and play with the car. Do some burnouts with traction control on and off to see how it reacts.
Had a similar issue today, left work without really letting the car warmup. Everything was smooth, pulled out on the road, easy acceleration thru the gears, then partly into 4th I get some shaking and traction control light blinking, only for 3-4 secs. It stops and all is well the rest of the ride, including some spirited driving after it warmed up. This issue sound familiar to anyone?
2013 gt manual track pack.
