track apps issues..
Old Sep 17, 2012 | 04:31 PM
going for broke's Avatar
track apps issues..
I have a 2013 with the track apps and on several occasions I have went in to look at the saved times and they are gone. all of the 0-30, 0-60, 0-100 accelleration tests will show 2.2 seconds and the timed area will show 100 seconds.. Has this happened to anyone else..? If so do you have a tune?
It's becoming a problem to have to go out and reset all of my best times every other week...
Old Sep 17, 2012 | 07:15 PM
JimC's Avatar
legacy Tms Member
I have the same thing happening. And now that you mention tune that may be the issue. I have been doing some testing and evaluating on different tunes for Doug and so have swapped tunes several times. I didn't make the connection that the history ends up cleared out after each tune is swapped until your post.
Glad I didn't tell the dealership to check that while they have the car (my ambient lighting keeps going out - mainly the red color goes out).
Old Sep 17, 2012 | 07:22 PM
I have only installed the tune one time so it's not clearing out because of a tune change. The first time it happened I thought it was on me but then I started paying attention and sure enough it's resetting on its own.
Old Sep 18, 2012 | 07:51 AM
jonny88's Avatar
I noticed mine said 2.3 seconds. I think I cleared mine out though bc I didn't get any good times. I'll check when I get home this afternoon. No tune on mine.
Old Sep 18, 2012 | 07:25 PM
13GuTh's Avatar
Convenient
"...No, seriously, I had a 4.5 second 0-60 time. Here, look...aw shucks, the computer "erased" it..."
I actually haven't used my track apps yet. Hopefully I don't have the same problem.
Good luck figuring it out!
Old Sep 19, 2012 | 08:09 AM
jonny88's Avatar
Well mine reset the 0-100 to 2.3 seconds I'll take that any day haha.
Old Sep 19, 2012 | 10:12 AM
MBarrette10's Avatar
I haven't tried using mine yet but hopefully they work when I do try.
Old Sep 19, 2012 | 01:09 PM
Mikey's Avatar
Mine won't save 0-30mph runs, and the times won't transfer to the "All Time Best" screen... Not sure what the issue is, but it doesn't bother me that much
Old Feb 20, 2013 | 06:01 PM
Shelby2013's Avatar
My Track Apps disappeared completely! LC, ride , and Steer buttons do nothing.
Anyone else have this happen?
Will have to see what the dealer says after I take it in.
2013 Shelby GT SVT "Fully Loaded"
Old Feb 26, 2013 | 06:58 AM
FordService's Avatar
Hello Shelby2013,
I recommend you bring your vehicle in to your Ford dealer and have it checked out. Then, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Old Feb 26, 2013 | 11:03 AM
Shelby2013's Avatar
Originally Posted by FordCustomerService
Hello Shelby2013,
Deysha
Thank you Deysha, That is exactly what I did yesterday. SVT guy said to try the other key, and that should allow me to reset the "My Key" feature. Unfortunately my dealership of choice is 1 and a half hours away. So, when I got home, I grabbed the other "Administrator" key, and I had full use of everything again. I then reset all keys to remove "My Key". All is good again. Found out that since I received the car, I was not using the Administrator key, and I had turned on "My Key". "My Key" lets you set restrictions and it disables the Track Applications. I did not notice this when it happened because I don't use the tracks apps very often.
Note to All ! Always take ALL of your keys with you when you take your car in for service or maintenance.
Old Feb 28, 2013 | 09:20 AM
You're very welcome, Shelby2013. Glad to learn all is well.
Deysha
Kalel08
Sep 29, 2015 03:06 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
