sync won't work at all
Old Feb 2, 2014 | 10:55 AM
Mr. V's Avatar
All of a sudden my sync won't work at all. The steering wheel button doesn't do anything. The button on the radio immediately switches back to the last audio source. Anyone else encounter this?
Old Feb 2, 2014 | 10:57 AM
Getportfolio's Avatar
Can you hear any volume with Bluetooth audio or radio ?
Old Feb 2, 2014 | 11:07 AM
Mr. V's Avatar
The radio runs fine. You can hear volume from other sources. Everything except sync. It's been intermittent since yesterday. No tone when you press the sync button on the wheel. Even the on radio button won't work. I'm so bummed.
Old Feb 2, 2014 | 04:25 PM
FordIVTteam's Avatar
Ford In-Vehicle Technology Rep
Hey Mr. V,
Since you aren't able to access your SYNC menu, I suggest removing fuse #3 while the engine is turned off. Replace it after 3 minutes and start the car to test your SYNC buttons. You'll find more information about fuses on page 236 of the 3rd printing of the manual: http://www.fordservicecontent.com/Fo.../12musog3e.pdf
Kim
Old Feb 3, 2014 | 09:03 AM
kylerohde's Avatar
This has happened to me maybe 4 or 5 times over 2.5 years of ownership. Simply turning the car off and restarting it has fixed it each time for me.
Old Feb 3, 2014 | 09:33 AM
Mr. V's Avatar
It's pretty weird. It just happened 3 days in a row after the car had been sitting overnight. Turning it off and on had no effect. The last 2 days, 10 minted into my drive, it just started working. The only new thing I've done is switch from an iPhone to the Samsung galaxy note2. The weirdness started on my 2nd day of ownership.
Old Feb 3, 2014 | 10:17 AM
tukatz's Avatar
I've not had Sync stop working altogether, but every now and then the system gets stuck on radio and insists there is no USB device. I have a thumb drive connected to USB2 and most of the time it works just fine with the system responding to voice commands. When it fails I turn off the radio and after restarting the car turn it on again. That usually resolves the problem.
Old Feb 3, 2014 | 05:55 PM
That is strange. Did you have a chance to try the fuse pull? If the SYNC controls have started working again, try performing a master reset instead, which is a great troubleshooting step: http://support.ford.com/sync-technol...ter-reset-sync
I'm glad your system seems to be working well now. Let me know if I can assist with anything.
Kim
Old Feb 4, 2014 | 06:49 PM
Mr. V's Avatar
I thought i would update everyone. This has been weird. I tried pulling the fuse and no luck. So i decided to try restoring the phone. No luck. I bought a new USB to mini USB cable. So far, problem solved. Lol, I hope that was the issue. Thanks to everyone for the suggestions.
Old Feb 5, 2014 | 12:09 PM
Great, Mr. V.
I'm glad everything worked out!
Kim
Old Feb 5, 2014 | 01:11 PM
Mr. V's Avatar
Lol. It happened again this morning. I guess I'll take it to the dealer
Old Feb 5, 2014 | 05:19 PM
jim010's Avatar
As of a couple of days ago, I am having the same issue.
A couple of weeks ago I had an issue with Sync not recognizing that there was and Ipod plugged in. It was intermittent. Tried master reset and seemed to work. Then problem came back. When I manually try to get the USB selected, it tries initializing but then gives up and says the ipod is not supported.
Now Sync is off altogether, just as you. Sometimes it comes back when restarting the car, sometimes not.
I am really starting to dislike this system. When I go shopping for a car again in a year or so, if Sync is standard, you may see me give your cars a pass, Ford.
Old Feb 5, 2014 | 07:23 PM
Mr. V's Avatar
Unfortunately for me, I'm hooked on this car. If it continues to give me trouble, I'll have to change the radio out. Maybe the Kenwood system that seems so popular on this forum. I was a car stereo installer 20 years ago. Lol, hopefully I can remember something.
Old Feb 6, 2014 | 10:53 AM
Hi jim010,
If you're losing the functionality of the SYNC controls, I suggest pulling fuse #3 while the vehicle is off. You'll find more information on page 236 of your owner's manual (3rd printing): http://www.fordservicecontent.com/Fo.../12musog3e.pdf Replace the fuse and test if SYNC is back to normal. If this does not resolve the concern, I recommend having your dealership look at your Mustang.
Let me know how the dealership visit goes, Mr. V.
Kim
Old Feb 6, 2014 | 11:54 AM
tukatz's Avatar
I have noticed one thing about mine that may be of help. If I turn the key quickly all the way to start, the radio comes on in radio mode, even if I had been listening to music on my thumb drive. If I turn more slowly through the first two positions and see the display showing USB, when I start the car all is well. Turning quickly to start doesn't cause Sync to fail altogether, but this info may help you understand what seems like erratic behavior.
Old Feb 6, 2014 | 12:27 PM
CiniZter's Avatar
i liked the excuse for buying kenwood
Old Feb 6, 2014 | 12:31 PM
Amariel's Avatar
That's interesting... On mine it seems random when I start up whether or not it will continue off the USB (which I never remove) or be set to 'line in'. I will have to experiment on different speeds of key turning to see if that gets it more consistent on starting on USB like it should...
Of course, as issues go, having to reselect usb is no big deal compared to things not working at all!
Old Feb 6, 2014 | 03:46 PM
Hey Amariel,
Unfortunately, there are no settings within the SYNC system that will allow you to select which source plays upon start up. Let me know if I can help with any other SYNC-related questions.
Kim
Old Feb 16, 2014 | 09:19 PM
explorerst4x4's Avatar
Did you delete the iPhone in your stored Bluetooth devices list? There is a setting for for default device and I am just guessing this could be a possibility. I would delete both and add them back and set the S4 as the default device. Worth a shot.
Old Feb 16, 2014 | 09:31 PM
Mr. V's Avatar
I deleted both and removed the fuse. I unplugged the USB cable and now it works. If I plug it back in starts being weird again. I'm going to the dealer tomorrow.
