No power or anything
Old Jan 9, 2024 | 07:27 PM
ElFrostedNuts's Avatar
Post No power or anything
hello im in need of advice and or help if someone knows whats wrong with my 2011 ford mustang v6 that i bought with my brother to rebuild and just mess around with. it ran fine when we were repairing it since it was crashed had no problems bought the bumper and lights and hood, only thing i changed other then body parts was the steering wheel airbag and painted the car, i took 4 years of ACR so im curtian i painted the car right and didnt get any overspray into the engine bay but now the car wont start nor do i get any signal from the computer, again the only thing not body ralated i changed was the airbag would that have affected anything or am i just screwd?
Old Jan 10, 2024 | 07:27 AM
05stangkc's Avatar
@ElFrostedNuts
Welcome!
During The Course of Painting Did You Do a Lot of Wet Sanding??
Perhaps You Got The Sjb Wet!
To Be Clear Car Cranks But No Start??
Not No Crank??
Any Trouble Codes??
Sjb & Water Intrusion
https://themustangsource.com/forums/...on-sjb-550481/
Pcm Communication
https://themustangsource.com/forums/...-newer-549894/
Shop Manual Pdf's Including Trouble Codes!
https://themustangsource.com/forums/...e-info-550475/
KC
Old Jan 10, 2024 | 04:29 PM
Siber Express's Avatar
Check all of your Connections on the battery, there are 2 fuses incorporated in the positive side and any type of shorting them out will blow them rather quickly.
Also when my truck had the airbag deploy Ford had to replace the ECU I do believe but that was to reset the Airbags, it was still able to start and drive.
red302pony
Sep 13, 2004 07:41 AM
1995mugt
1994-2004 V-8
Aug 8, 2004 12:44 AM
