My traction control came on for no reason today. Was making a left hand turn and gave it a little bit of throttle and the light started flashing on my dash. I turned of traction control but it still flashed. I guess next time I will have to turn off Advancetrac. I'm going to take a video of it next time.
Could you get someone else to make the video, while you, you know, drive?
Sounds like it is working as designed.
This isn't completely related, but you can take some of the information for diagnostic purposes. I've been getting traction control and ABS lights on my Monte Carlo. On the FWD or 4WD vehicles, the front hub assembly has the sensors for traction control in the front. I replaced the hub assemblies on the Monte Carlo and the issue went away. I started having issues again after two months and replaced the passenger hub assembly again. I found the sensor was reading 14 mph faster on the passenger side. The sensor misreading was sending the signals that the tire was spinning and activated traction control. It's starting again and I was told by a shop that I need to find a different brand of hub assembly because the sensors aren't syncing correctly.
Originally Posted by AzPete
(Post 6824065)
Originally Posted by dave07
(Post 6823913)
(Post 6824889)
I guess I should have mentioned I was driving like a granny. Let the clutch out at idle, shift at 2500 RPM. All I did was turn at a light and go in a tangent. The brakes were applying themselves for about 20 seconds after the turn.
Have you advised your dealer of this? Also, let me escalate this for you as well. Since I already have your info, PM me with your dealer, and best daytime number. Deysha |
Just got aimed here. Mine did the same thing, too, last week. I'd just pulled out for my morning commute and the light came on and brakes started pulsing. I turned off TCS and it stopped. Then I gave the brakes a good hard application and flipped TCS back on. No problems since. Weird.
Originally Posted by bkrell
(Post 6828453)
Have you addressed this with your dealer? I’d also like to get this escalated to the customer service manager for your area if needed. Please, PM me with your VIN, dealer, mileage, full name, and best daytime number. Deysha |
This happened on my 12 GT vert today. Wierd. First time I have ever seen this. @ 22,000 miles. I kepth pushing the traction control button on/off and no change. After about the 6th time I pushed it, both lights went off. I'm going to watch it now. I will have my dealer check it out at the next oil change.
Originally Posted by redneb
(Post 6829910)
Deysha |
Originally Posted by scottmoyer
(Post 6824781)
Originally Posted by FordService
(Post 6831050)
Please do so and let me know the outcome, redneb. Deysha
(Post 6832202)
Thanks for the note Deysha. I will let you know if it happens again and what the dealer finds. Love my GT!
Deysha |
It happened to me for the first time today. I have 12k miles. I was driving about 10 or 15 mph about to make a right turn. I pushed on the brake and all of the sudden the brake pedal began pulsating, basically my abs kicked when it shouldn't have. Then I made the right turn and noticed while accelerating slowly that my rear brakes were randomly applied on each rear wheel. I let go of the gas and it went off. These two episodes lasted about 2-3 seconds, I did not see any lights unless I missed seeing them.
Bump.
Happened again to me today. Anyone have a solution to this? |
2014 GT - Happened to me too
Two days ago I went to mildly accelerate onto highway and at about 30 mph both lights came on (ABS and Anti skid) and car began lurching to the right and back, to the right and back as if I had a complete flat, or as if my right tire had locked up and released repeatedly, on its own. Pulled over, looked around, saw nothing, got back in and felt it again immediately along with both lights flaring up again. Turned car off and back on and drove slowly off highway. Has not occurred again. And I pray it doesn't. If this happens at high speed it could be fatal. |
