Jerkiness/stuttering in first gear?
Old Apr 10, 2012 | 08:27 AM
Grifftech's Avatar
I am noticing a jerkiness/ stuttering in first gear. It usually happens when I am downshifting coming to a stop light and right as I am about to shift into first the light turns green and I go ahead and shift into first and begin to accelerate but the car kinda lurches and stutters.
It only seems to do it when I have any forward motion then trying to accelerate in first. But from a dead stop it doesn't seem to.
Anyone else experience this?
Thanks,
Chris
Old Apr 10, 2012 | 08:29 AM
LEwis26's Avatar
Every stick shift car does this. You need to be very smooth on the throttle for it not to do it.
Or if you are already moving, just go to second.
Old Apr 10, 2012 | 08:35 AM
Grifftech's Avatar
I thought so, it just felt like something was slipping or not right. But wanted to make sure.
Old Apr 10, 2012 | 10:02 AM
HizliBullet's Avatar
First gear is always to lift the car off the ground, never use first gear to slow down
Old Apr 10, 2012 | 12:05 PM
stevegt2012's Avatar
+1 on if you're already rolling use second gear.
Old Apr 10, 2012 | 02:03 PM
2012GTCS's Avatar
I guess I will be saying the same. I would never/don't shift into 1st if my car is still moving.
Old Apr 10, 2012 | 02:39 PM
kcoTiger's Avatar
I did it once, when I was 16. The sound I heard from the engine was so terrifying I've never done it again. I use compression braking all the time, but I do so with 2nd gear, never 1st.
What was that sound, you ask? It was my transmission going into its death throes and spraying itself all over the pavement in pieces.
Old Apr 11, 2012 | 07:20 AM
Mossberg's Avatar
I've never seen a manual that DIDN'T do that.
Rando
Aug 25, 2021 11:12 AM
AMAlexLazarus
Oct 15, 2015 11:06 PM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
