Fuel Rail Pressure Sensor High Input
Old May 27, 2019 | 12:32 PM
phxknight's Avatar
I'm getting a Fuel Rail Pressure Sensor High Input error. The check engine light only goes on with over half a tank of gas, but the error still shows up when plugged in for diagnostics. Can I service this somehow to get it off the computer, or just bite the bullet ?
Old May 28, 2019 | 04:31 AM
David Young's Avatar
'If' it is the sensor, I would replace it. Appears to be around $160 . Should be youtube videos on how to replace it
Old Mar 6, 2020 | 12:44 AM
great's Avatar
I have checked the wire from the PCM to the connector at the FRPs and its ok. Back probed the wire to the PCM, no voltage. I say no voltage but i checked it with a test light. I also have no codes. I have disconnected sensors to see if it will give an engine check light or code but none. There is communication though to the scanner/ code reader but says the EVAP is not supported.
Spam Removed
Kc Admin
haitham
Sep 8, 2015 12:52 PM
verslaflamme
Oct 16, 2014 05:09 PM
Burke0011
Nov 16, 2007 09:31 PM
don_w
42
May 3, 2006 01:39 PM
