Electronic Power Steering Rack Recommendations
Hey all,
My EPSR died as I pulled into my driveway last night and need to repair/replace it. From what I have seen online it is not really something that I will be repairing so I started looking at replacement parts and holy crap are they expensive (for me).
I would like to know if anyone has strong opinions about buying used ones off ebay. I have had good luck with buying used equipment before (not just for cars) and since this part seems like it could last for the life of the car it appears to be a good candidate for getting used.
Thanks for all your thoughts.
2012 Ford Mustang V6 convertible coup 3.7 liter base trim. Everything stock. No mods of any kind.
Get a Reman and Don't get Somebody Else's Used Up Rack! Steering & Brakes are Areas You Don't Want to Cut Corners On! The Fact So Many are Backordered on Rock Auto is They Have a High Failure Rate! Start Fresh! Get One While You Can!
As an FYI The Reason You See The Wheel Size Choices Are Because The Larger Tire Cars Have a Shorter Lock To Lock. So A 17 Wheel Rack on a 19 Inch Wheel Car May Rub On The Inside!
That is My 2 Cents!
https://www.rockauto.com/en/catalog/...nd+pinion,7388
KC
That is My 2 Cents!
KC
I Cross Referenced an Oem Steering Rack Part Number for 17" Wheels!
OEM / Interchange Numbers: BR3Z3504A, BR3Z3504DE, BR3Z3504GE, BR3Z3504KE, CR3Z3504AE, DR3Z3504AE
Here is Oem Listing For 17"
https://www.fordpartsgiant.com/page_...stering%20rack
Here You Go!
https://www.rockauto.com/en/partsear...num=DR3Z3504AE
Here You Go!
Oh wow thanks a lot! So for the future, the workflow is: find part number, convert it to OEM part number, then search for all equivalent parts via the rockauto search engine?
KC
