Driveline vibration, 65-85mph?
My 2014 5.0 6AT has about 1800 miles on it, and I'm starting to notice a driveline vibration while on the highway between 65-85 mph.
I've ruled out a tire balance issue, as the issue goes away between the on-off-on throttle when maintaining traffic speeds. What the car has is a very light vrrrrb sounding vibration during light throttle or deceleration when a load is present on the driveline, which is nearly constant during my 35-mile commute.
Anyone else have this?
sounds like the drive shaft is resonating. I'd take it to the dealership, drive it with the tech/service manager in the car, then drive one of their new ones on the lot to point out the difference.
If they don't want to play nice, sic Deysha on them.
John
Hotrod1950 (5/12/16)
It's an expensive fix, but one option to consider is going to a one-piece driveshaft. If you track your car at all, it will provide some benefit over the two-piece, and of course it will take out some of the looseness during daily driving. It will also remove any resonance provided it's installed properly. If I had a 5.0, it's the first thing I'd change.
If you really think it is 'worse' than your previous examples you can take it in but I wouldn't be surprised if it's a bit tough to get help.
That's a hard thing to troubleshoot and frankly the 'acceptable' range with these vehicles is so wide I really think any noise is expected in some examples unfortunately... GL
Maybe it will diminish a little over time, but I was hoping someone else would have had the issue and could tell me exactly what the fix was.
If it stays the same, I will probably change the driveshaft out to an aluminum one, but only after if visits the Ford Service Center once to get documented and looked at. If Ford finds something, unlikely, I will post an update to the cause.
I had a vibration caused by the rotor retainer clips. It was making my rim not sit flush with the hub. I took the clips off and vibration was gone. If you have stock rims this shouldn't be an issue though.
I just bought a 2014 GTCS with the 3.73s. I have the SAME issue! It is not the tires. It is definitely coming from the drivetrain. The worst part of the vibration is when you let off the gas and it coasts down between 80 to 60, it really makes a vibration! I am dealing with the dealership right now, but I have a feeling I am going to be told it is within tolerance. Drives me BatChit at 75 MPH! Which is how fast you must drive on the Washington Beltway without getting run over!!!
I just bought a 2014 GTCS with the 3.73s. I have the SAME issue! It is not the tires. It is definitely coming from the drivetrain. The worst part of the vibration is when you left off the gas and it cost down between 80 to 60, it really makes a vibration! I am dealing with the dealership right now, but I have a feeling I am going to be told it is within tolerance. Drives be BatChit at 75 MPH! Which is how fast you must drive on the Washington Beltway without getting run over!!!
Good to hear, Bill. Thanks. The service department will get sick of me before this is over, if it does not get fixed.
Has this concern been resolved for you?
Please have your vehicle checked out at your Ford Dealer and PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Deysha,
Not for me and I agree, it is annoying. I waited to see if on the outside chance different wheels and tires would make a difference and as predicted, they didn't. This is definitely driveshaft frequency. I've also noticed a lot of clunking in the driveline like ring/pinion play, U-joint/CV joint play or slip joint play and my guess is the problem is with one or more of them. Earlier, when I brought the car into the dealer for the issue, they said everything was normal. I respectfully disagree with them. The driveline in my old '86 F-150 with 168k miles on the clock runs smoother and quieter. Now that I have $3000 worth of wheels and tires on the car I'm terrified to have a Ford tech even touch the car.
John
John
Deysha,
Deysha
Hopefully the dealers are checking the driveshaft run-out's to spec.
Max driveshaft runout: 0.035" --- Max pinion flange runout; 0.009" ---
Max trans flange runout; 0.008".
I had a driveshaft that had the trans flange runout to spec but the mating flange welded to the driveshaft was off.
I have the same issue but nowhere near as bad as you guys.. 2014 Track Pack, 2500 miles. At 80 mph, the rear view mirror goes fuzzy from vibration, then disappears at 90.. has to be the driveshaft.. it's much higher frequency than a wheel balance or wobble issue. The 3.73 gears contribute to this issue.
Deysha, thanks for the advice (I'm Serious) but I'm not going to swap out my new wheels and tires with the old ones just because a mechanic may not treat the expensive ones with the respect due them and his customer. I've proven, at least to myself, that the wheels/tires are not the problem simply by swapping one set for another and having the issue persist. Having raced for 20 plus years, I know the difference between driveshaft frequency and wheel frequency. My problem is how to get the dealer mechanic to tune into what I'm saying. If I didn't feel it was a warrantable situation, I would work it to resolution in my own garage.
Thanks,
John
Marcin
A Man Just Needs Some....
