Dash door light warning
Today I noticed the dash light indicating either the door or trunk was open. I drive a convertible so got out checked the two doors by opening and closing and same with the trunk. The light never went out until turning the car off. Is that a fuse issue?
Originally Posted by Macgould
(Post 7085682)
12 Attachment(s)
Yep Likely a Switch! BUT JUST A GUESS!
I Think a Code Reader That Can Read {BODY CODES} Would Pin Point it. Can't Recall For Sure? Gonna Move You To Repair & Service Issues! Usually The Most Used Access Point. Drivers Door Best Guess! Here is The Ford Switch I Do Believe For Drivers Side! https://www.fordpartsgiant.com/parts...tra2=&filter=() The Goofy Thing Is The 2012 Shop Manual Just Omits The Switch Install Part So You Need To Look at Earlier Car PDF. Go Figure. https://iihs.net/fsm/?d=466&f=Door%20Ajar%20Switch.pdf KC https://cimg4.ibsrv.net/gimg/themust...69bc72b349.jpg A Hail Mary Pass With Some Contact Cleaner Sprayed Downward May Clean Switch Enough To Get Light Out! Worth a Try. POINTING MORE STRAIGHT DOWNWARD! Could Do Both Doors! https://cimg2.ibsrv.net/gimg/themust...344010a385.png The X is About Where Switch Would Be Inside Door! https://cimg6.ibsrv.net/gimg/themust...24693a5bae.png https://cimg0.ibsrv.net/gimg/themust...7c93c1a7f1.png Number 3 is Luggage Lid Switch! Again This is Earlier Car Maybe Different on 2012 Does Not Show Switch on 2012 Shop Manual! |
My guess would also be a switch as well.. :dunno:
(Post 7085700)
It's been pouring down rain here, a lot so today between storms finally got to try out the ideas you guys submitted. It's fixed. Definitely not the fuse, sprayed into the area recommended and tried the doors. Light out, Thanks everyone for the advise. |
:):nice:
Sometimes A Little Cleaning Brings Desired Results! After So Many Years The Original Lube Will Turn To Gum Like Consistency! KC |
| All times are GMT -6. The time now is 08:55 AM. |
