Battery draining - "Cluster (Battery)" fuse
Old Feb 5, 2017 | 03:03 PM
Skandocious's Avatar
I've got about a 500 to 750 mA amp draw when the car is off and I think I've isolated it down to a fuse labeled "Cluster (Battery)" -- fuse #26 in the passenger interior box. Anyone know what this circuit is or why it might have a constant draw?
This is a 2013 Mustang GT/CS.
Old Feb 5, 2017 | 04:35 PM
m05fastbackGT's Avatar
Try the search forums function.. There's plenty of threads in which you'll find valuable info addressing this topic..
Old Feb 5, 2017 | 04:46 PM
I've searched extensively already (both here and on google) and came up empty handed for this particular issue. Perhaps you can point me to the threads you're talking about?
Old Feb 5, 2017 | 10:30 PM
Here's the link below.. All you do is just type in the search box- draining or dead battery and all the threads will display..
https://themustangsource.com/forums/...archid=5936348
Old Feb 6, 2017 | 08:10 AM
That is not my question. My question is what does this fuse mean-- read my post.
Also your link doesn't work.
Old Feb 6, 2017 | 01:25 PM
You type in dead battery or drained battery A.K.A keywords, just as I previously stated... Therefore I read your post.. Here's the links once again, if they stop working.. Just type in the keywords that I mentioned in the search box !
https://themustangsource.com/forums/...archid=5936576
https://themustangsource.com/forums/...archid=5936577
https://themustangsource.com/forums/...archid=5936586
Old Jul 20, 2022 | 09:18 PM
EzeMustang's Avatar
battery cluster fuse 26
Hey Skandocious, having same issue, did you find out a solution after all ?
Old Jul 21, 2022 | 01:56 PM
Apparently he didn't find a solution... Also just a heads up in case you didn't notice, but the last activity on this thread was from 5 years ago...
Old Dec 30, 2022 | 07:54 AM
Killerbunney's Avatar
Cluster battery solved, kinda
Experienced this problem after some trouble shooting and a little research I found you have to wait 15-30 min for the cluster to enter sleep mode.test without breaking the circuit. I went from .70 to .08 by waiting. My original problem was caused by registration stuck in the flap of the vanity mirror. Hope this helps someone because it drove me crazy.
