All of a sudden, mine won't start
Old Jan 17, 2012 | 06:10 PM
CaptDistraction's Avatar
Any 2011+ mustang experts around? Mine won't start, checked keys, battery fuel, no turnover on key to ignition, checked relays on starter and changed them with neighbors, reflashing ECU, checked connector on clutch NSS and manually pressed it. No DTCs, no warning. Just seems like no power to starter. About to roll it back and jack it up for inspection of starter power.
Car has good fuel, 13.2V on battery, and no other odd behaviour.
Old Jan 17, 2012 | 06:28 PM
AzPete's Avatar
Do you have any power with the key in the on position.....radio, windows, heater.......
Check all the ground connections under the hood. Could have corrosion.
Old Jan 17, 2012 | 06:37 PM
COYOTEHP's Avatar
try holding gas pedal down and starting
montreal ponies's Avatar
Why do you have to go through all that trouble, isn't your car still under warranty ! Have it towed to your dealership.
Old Jan 17, 2012 | 07:55 PM
2010MustangGT's Avatar
Is the PCV valve (the piece many replace with a JLT oil separator) fully latched on? 'No power to starter'....Doubt it, but a fuse?
Old Jan 17, 2012 | 10:17 PM
2012GTCS's Avatar
This is kind of awkward. May seem like the cheap way out but before I'd start messing with things and getting more Involved, I second just getting It to the dealer.
Old Jan 17, 2012 | 10:28 PM
yugoboss's Avatar
Try moving the tilt steering column up and down then try it. We had a 2011 expedition in for a service that did the same thing. Started when it came in, but did not want to when leaving. Played around with the tilt, and off she went.
Old Jan 18, 2012 | 12:16 AM
Will3212's Avatar
this, try turning the wheel while starting, the steering wheel may have locked up
Old Jan 18, 2012 | 01:51 AM
HizliBullet's Avatar
push the clutch in
Old Jan 18, 2012 | 01:59 AM
tom_vilsack's Avatar
Ring Ring...Hi ford dealership my zillion dollar mustang under warranty won't start...get out here with a tow truck and loaner car...and maybe bring me a warm coffee also...done...click.
Old Jan 18, 2012 | 02:50 AM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Ring Ring...Hi Mustang owner, this is ford dealership returning your call, you've added an intake, CAI, tune, etc. that voids your warranty, its your problem now....done....click.
Old Jan 18, 2012 | 03:59 AM
David Young's Avatar
I was thinking the same thing...........
Old Jan 18, 2012 | 04:04 AM
I must add........Move around the steeringwheel, like others have said. I think its called a 'clock spring', (something like that) could be going bad.
Old Jan 18, 2012 | 01:51 PM
Fat Boss's Avatar
Originally Posted by TOGAN
push the clutch in
If it won't turn over I'd look at the switch on the clutch pedal.
Old Jan 18, 2012 | 02:03 PM
Eventually it started again.
So the situation was/is this:
-Key on power was good
-Accessories would run
-you could hear the starter relay trigger when key pushed to start
-No noise or movement from starter
-I did not look for theft light, play with clock spring, or otherwise (did try both keys)
-Eventually on one start attempt at the very end the starter began to move
-Next start attempt and every one since the car starts normally
Either loose wire, or something's overheating, I'd think. It is going to the dealer, but I wasn't in a position to get it to a dealer when it left me stuck at a gas station.
Old Jan 18, 2012 | 03:35 PM
S197 GT's Avatar
3rd Times A Charm
Have you wired anything up recently?
Looking at your mods, nothing listed could really contribute to a wiring issue...
Are you running a shift light? Additional lighting? Stereo equipment? Anything that you may have tapped into your ignition for power?
Never heard of any starter issues with these, but that really doesn't mean anything.
Did you have any signs of this during the summer months?
No long tubes right?
Old Jan 18, 2012 | 04:42 PM
nothing touching ignition circuits, factory exhaust (through midpipe, despite being a boss midpipe, its factory ford parts).
I'm thinking maybe a loose connection on the starter, given how many other items have been lazily serviced or left loose on my car by the local quality ford dealers.
Old Jan 18, 2012 | 05:30 PM
iBookmaster's Avatar
If you have a power converter plugged into one of the power supply outlets that allows plugging in regular electrical plugs that has been left on, it will drain your battery. Happened to me with my 2008 Mustang.
Old Jan 18, 2012 | 05:46 PM
pony racer's Avatar
might just be a low battery..
testing it with a volt meter and it shows 12.6v just mean it has 12.6 volts.. but if it doesnt have any current it wont start the car i would load test the battery.. but you can still use the radio.. esp. if you heard a click when turning to the start position and nothing happend.. or it can be a loose + battery cable that is grounding out, which has happened it it will do the exact same thing as your describing..
Old Jan 18, 2012 | 08:31 PM
born2run74's Avatar
I've had the exact same thing happen in both my 05 and 2011. Completely random, just a click when you turn the key. Mine eventually started, I never investigated it but I thought it could have something to do with some electrical interference with anti-theft chip in the key fob...?
