AC not blowing cold at idle
Old Jun 14, 2016 | 10:35 AM
SpeedCostsMoney's Avatar
I have a 2010 Mustang GT convertible with 30k miles. I have a AC issue I can not nail down. I took into the shop and they are saying the system is blowing at 52 degrees which is spec and no leaks. However, when it gets above 90 degrees outside the AC is not blowing cold air at idle sitting in traffic and when you are pressing the gas (like passing). I checked and made sure the fans are kicking on and nothing is blocking the radiator and condenser.
Anyone else had this issue? What else can it be? Do I need to take it back in to the dealer? I know the car is triple black and I am using a sun visor and cracking the windows.
Old Jun 14, 2016 | 11:05 AM
SpectreH's Avatar
I don't know if the Mustang does this or not, but some cars disengage the compressor at wide open throttle. If so, that would explain your second issue. Not sure what to tell you on the idle issue.
Old Jun 14, 2016 | 11:16 AM
I figured as much but I sit in traffic a lot and the AC is not keeping up with the heat down here.
Old Jun 14, 2016 | 11:24 AM
SpectreH's Avatar
Is this a problem that just cropped up, or has it always been this way? Also, where within the spec is 52 degrees? If it is on the border of being out of spec and the problem is new, I'd wonder if the compressor is on the way out.
Old Jun 14, 2016 | 11:29 AM
This is the first summer with this car so I am not sure if this is normal. It seems to be fine anything under 90 degree weather. I know I got a black car with black interior but this is ridiculous.
Old Jun 16, 2016 | 05:05 AM
I took it by the dealer and they did a evac and recharge with a leak test. There were no leaks found. They did notice the PCM was out of date and there was a upgrade that addresses the AC issue. They did a upgrade of the software and now the car's AC is blowing cold as ice.
Old Jun 16, 2016 | 05:41 AM
SpectreH's Avatar
Glad you got it fixed!
Old Jul 18, 2016 | 09:57 AM
jungleehiren's Avatar
Did they confirm that the old software was causing the a/c to not work and the new update solved the issue for your car? (is this the recall update/upgrade of the software) or something totally different?
My a/c is not working right now, I have scheduled to go to the dealer this weekend for the software update which is a part of recall.
Please let me know about software.
Thanks,
H
Old Jul 18, 2016 | 10:34 AM
I am not 100% sure sine they did evac and recharged the system before the update. However, they said there was not a leak and the software upgrade was the issue. Something about the fans not spinning at the right speed. My issue worked before just now well.
Old Jul 18, 2016 | 11:35 AM
Gigantor
05-09 Exterior Modifications
Sep 20, 2022 11:12 PM
sdeca29
Apr 15, 2016 02:11 PM
Ragwingr
Mar 26, 2016 07:28 PM
emba129
Mar 21, 2016 10:33 AM
bluebirdbass94@gmail.com
Mar 20, 2016 10:32 AM
