36K Miles Service (what to check).
Hey Guys,
Coming up on my 36K warranty... (I'm at 34.5). It'll make for 23 months!
I want to get the last overhaul in. Anything to especially take note of? Doesn't Sync expire? Car has been running great.
I believe the manual 30K is the following... So I'll at the minimum ask for these.
❑Change engine oil and replace oil filter
❑ Inspect automatic transmission fluid level on
vehicles if equipped with dipstick. Consult
your dealer for particular requirements.
❑ Replace cabin air filter (if equipped)
❑ Replace climate-controlled seat filter (if equipped)
❑ Replace engine air filter
❑ Replace fuel filter (except Escape, Mariner,
F-Series [non Super Duty],
Expedition/Navigator [short wheel base only],
E-Series and Transit Connect)
❑ Inspect steering linkage, ball joints, suspension,
tie rod ends, driveshaft, and U-joints (lubricate if
equipped with Zerk fittings)
❑ Torque the rear U-bolts (Transit Connect only)
❑ Inspect engine cooling system and hoses
❑ Inspect brake pads, shoes, rotors, drums, brake
lines and hoses and parking brake system.
❑ Inspect half shaft boots (if equipped)
❑ Inspect exhaust system and heat shields
❑ Inspect and lubricate 4x4 front axle U-joints
❑ Rotate tires, inspect tires for wear and measure
tread depth
❑ Inspect the wheels and related components for
abnormal noise, wear, looseness, or drag
❑ Perform multi-point inspection (recommended)
tread depth
ssjbuu
8/28/15 08:55 AM
