2013 GT Radio LCD Display - Recognize This?
You could tell where the peel away decal had been on my new screen. They took it off after installation. From what I have learned is that the FDIM is not the radio itself but the screen but I'm not clear on what screen it is. The one on the radio itself or the one mounted into the front cover panel that looks damaged on our cars.
My work order says they inspect, verify concern, removed and replace radio unit as needed, retest.
I'm going to assume that means I got a new radio. My radio presets were correct from what they were before so I guess they have some way of retaining that info or maybe they just wrote them down and reinstalled them.
I think it is interesting that some people are supposedly getting new radios as well as the new front cover and some people are just getting the front cover.
Wayne
I'm glad to see I'm not the only one with the radio surface delamination issue. About 3 months ago a small spot appeared and finally took over my entire radio surface. It was almost impossible to see with the light shining on it. I knew I had never cleaned the surface with anything so I had no idea what it could be. I was in the shop getting an oil change and mentioned it to them and they told me they get about 1 a month of these happening on the Escapes and only had it happen on a few Mustangs. They ordered the module for me and replaced it today in about 15 minutes free under warranty. They said they're not sure what causes it but think it's heating/cooling or the sun.
Deysha
my screen does the same thing as well. I thought it was kind of frost effect since it is bitter cold recently and my windshield does get frost inside every morning. Until I go across this post, I can't believe it is defect and need be fixed.
Thanks everyone, I will let my dealer work on this next time I dropping by.
The replaced part is only screen itself, radio set is kept untouched.
Update: couple days ago, I brought my car to dealer have them check it out and confirmed the issue. Dealer ordered part and replaced the screen two days later. Dealer also updates the sync and brought me new "mustang" message and additional vertical lines. Very happy.
So are brand new '14s coming out of the factory the last couple months still coming with this old problematic screen or are they coming with updated screens and the sync updates with the lines and Mustang text at startup?
When I got mine fixed back in January on my base model car that does not have sync, I got the line and the "mustang" text at startup. I don't know if the new 14's have the updated screens. They should since the special service message addressing this problem came out in October of 2013.
Wayne
Wayne
It's a Sync update. The radio they put in your car was most likely sitting in stock for several months therefore doesn't have the latest update.
Here is what the SSM says on this issue. Since my car does not have sync, that is not the reason I now have the blue line and the "mustang" message after my repair.
I'm also not totally sure what was replaced during my repair other than the screen in the "front control interface module" as the SSM describes it is new. I'm not sure if the FDIM is the actual screen on the radio itself or it's the screen in the "front control interface module". That is where I'm confused. My repair order says "replace radio" so I'm assuming the entire radio is new but I could be wrong.
OASIS SPECIAL SERVICE MESSAGE NUMBER: 44226
MESSAGE TITLE: Multi Vehicle Line - Front Display Interface Module (FDIM) Display Distortion
APPLICABLE VEHICLES :
2011 CAR : 00122 FOCUS
2012 TRUCK : 00189 FLEX
2012 CAR : 00170 FUSION
2012 CAR : 00117 TAURUS
2012 - 2013 TRUCK : 00029 F-SERIES LD
2012 - 2014 CAR : 00071 MUSTANG
2011 TRUCK : 00163 MARINER
2011 - 2012 TRUCK : 00130 ESCAPE
2011 CAR : AU FOCUS (CW170) - N.A.
2011 TRUCK : M7 ESCAPE/TRIBUTE/MARINER-LHD
2012 CAR : DE FUSION/MILAN/MKZ (ZEPHYR)
2012 CAR : PH TAURUS
2011 - 2012 TRUCK : M7 ESCAPE/TRIBUTE/MARINER-LHD
2012 - 2013 TRUCK : F6 F150/LINCOLN MARK LT
2012 - 2014 CAR : ZF MUSTANG (S197)
OASIS MESSAGE :
Some 2011 Focus, Mariner; 2011-2012 Escape; 2012 Flex, Fusion, Taurus; 2012-2013 F150; 2012-2014 Mustang vehicles may have a distorted FDIM display often described as being delaminated, frosted, cloudy, hazy, faded, and/or foggy. FDIM service parts have been improved and are now available. Base Part Number 10D885. Please use available labor times to correct the condition.
APPLICABLE SYMPTOM CODES :
1***** Comfort & Entertainment
112*** Comfort & Entertainment > Audio
1126** Comfort & Entertainment > Audio > Display/Multifun
112636 Comfort & Entertainment > Audio > Display/Multifun
112638 Comfort & Entertainment > Audio > Display/Multifun
200000 ELECTRICALmp; Entertainment > Audio > Display/Multifun
207000 ELECTRICAL ENTERTAINMENT SYSTEMS Audio > Display/Multifun
The FDIM is not the radio, it is the actual screen, stands for Front Display Interface Module. The radio unit itself is actually called an Audio Control Module. The part with the buttons is called the Front Control Interface module. We also have Accessory Protocol Interface Modules (sync) and Human Machine Interface Modules.
OASIS MESSAGE :
Im also having this issue with my new mustang. I noticed it about a month after I had the car, and I baby it so I know I didnt cause it. I went to my local dealer and they told me it would not be covered and that I would have to pay to repair it.
This is a recurring problem with this defect because it fails in a way that looks like it was damaged.
Deysha
Are you guys getting this fixed under warranty? My dealer told me that I put the scratches in the screen and won't fix it. Which is total BS. It was cloudy, I took it in and they "detailed" the screen and put all these scratches in. Has anyone replaced the screen? I'm thinking about doing it.
