2012 Mustang GT Squeaky suspension came back after dealer fixed it.
Old Jun 10, 2011 | 08:35 PM
Will3212's Avatar
I have a 2012 mustang gt stick with just 800 miles on it. A month ago I took my car to the dealer for a squeaky suspension in the front. After taking it to the dealer the mechanic said it was a bad control arm. They replaced both front control arms and the squeak was gone. Now a month later it came back. When I go over a bump at a low speed I can hear a squeak coming from the front. Thing I don't get is if they replaced the front control arms with new ones just a month ago how can it mess up again?
Old Jun 10, 2011 | 08:46 PM
SD CALSPCL's Avatar
Based on what happened with my wife's 2009 Passat Wagon, it could be a bushing problem, VW had control arm bushing problems, no recall, but a service letter to take it in if the car was making noise. Had them replace the bushing at 24000+ miles and no more squeek. I would suggest you have the dealer check to insure the bushings are seated properly, and all the attachment points are tight.
Definitely return to the dealer since they did the work.
Old Jun 10, 2011 | 09:19 PM
Will3212's Avatar
it's weird because after they replaced the control arms the squeak went away for a month. so i really dont know what it is
Old Jun 10, 2011 | 09:57 PM
vdub2stang's Avatar
Brought my car in for the same issue. They replaced my front sway bar about 2k miles ago and no more squeak (so far).
Old Jun 10, 2011 | 10:22 PM
Will3212's Avatar
what year and how many miles is your car? vdub?
Old Jun 10, 2011 | 10:25 PM
Will3212's Avatar
it's frustrating when you think the dealer fixed it when they didn't and you have to take a day off work just to bring it to them again.
Old Jun 11, 2011 | 11:27 AM
Modshack's Avatar
Dealer "techs" have become nothing but parts replacers. It's easier and they make more money this way than actually diagnosing a problem. Sway bars don't go bad. A simple lubrication of the sway bar bushings with the correct lube would have fixed the problem. Likely the OP has a similar situation.
Old Jun 13, 2011 | 08:51 AM
FordService's Avatar
Hi Will3212,
Could you message me with your VIN, contact info, mileage, and dealer? I’d like to get this escalated for you.
Deysha
Old Jun 13, 2011 | 10:05 AM
Will3212's Avatar
Originally Posted by FordCustomerService
Hi Will3212,
Deysha
I brought it back to the dealer again and they sprayed silicone grease on the squeaking part. The noise is gone now.
Old Jun 13, 2011 | 08:56 PM
Tony Alonso's Avatar
Which part were you told was noisy?
Old Jun 14, 2011 | 09:01 AM
Oh, ok. Please, let me know if you ever need my help.
Deysha
Old Jun 14, 2011 | 12:25 PM
J1000's Avatar
FYI, mine has the same issue. They called the Ford Hotline, and Ford gave the dealer a list of things to check on the car. I strongly suspect LCA bushings.
Old Jun 19, 2011 | 12:18 AM
Will3212's Avatar
alright now this is getting frustrating, the noise came back! The squeak in the suspension came back, I just made another appointment with Di Blasi Ford, in Corona NY on Wednesday. I don't understand what's wrong
Old Jun 19, 2011 | 06:30 AM
MyStang2010GB's Avatar
the silicone grease spray they used wore off. That was a bogus fix....
Old Jun 19, 2011 | 02:05 PM
Will3212's Avatar
i just messaged deysha with my vin number, dealer info, and contact information. I'm bringing it in Wednesday you think they'll find the problem this time? the squeak is very bad and loud
Old Jun 19, 2011 | 03:09 PM
Will3212's Avatar
last time he said the controls arms are bad and are causing the noise. After they replaced them it was good for a month. Now after a month the squeak noise came back.
Old Jun 19, 2011 | 04:42 PM
I presume they replaced the bushings, along with the control arms. Do you know if that is the case?
Old Jun 19, 2011 | 07:13 PM
Will3212's Avatar
They told me they replaced both control arms, I guess this means it's the bushings too. They didn't say anything about bushings. After the silicone grease and the new controls the squeak noise came back a month later. It was good for a month after the fix.
Old Jun 19, 2011 | 09:29 PM
One would presume they did, but given the noise returned, I wonder if they did. Or as mentioned above, perhaps there was a bad batch of parts.
Old Jun 19, 2011 | 10:04 PM
Will3212's Avatar
yeah it was probably the bad batch of parts. So when i take it to the dealer wednesday should I tell them this or just don't say a word and just tell them the suspension is acting up again with the same exact noise.
