'12 V6 Mustang with TIS Wheels (balance issue)
I just purchased a 2012 V6 black Mustang that came with 20 inch TIS wheels. I am new to the Mustang world, and after some research, I understand that these wheels came on a special "DUB" Edition last year.
I suppose my rims and tires were left overs as part of that package, and the dealer put them on there. They really set the car off and look great, but they were never balanced properly.
I local tire shop (paid by the dealer) tried two times, and there is still vibration in the steering wheel. There is no particular speed at which the vibration is worse. It comes and goes, but it is annoying, especially in a brand new car.
I am taking it Monday to get a road force balance, hopefully that will solve the issue.
Anyone have thoughts on how to properly balance 20 inch wheels?
I know that the steering wheel shimmy isn't normal, even on 20 inch wheels.
Am I right?
Am I right?
Try swapping the wheels front to back and see if there is a difference. It may not be the wheels.
Any good shop should be able to balance any size wheel and tire..........
Has anyone looked for a slightly bent rim?
Gonna have them inspected tomorrow by a tire shop in Little Rock who says they can take care of it. I am hoping to get it taken care of. I am tired of stressing over this. I love my new car, just want it to drive like one. I am hoping it's not a bent rim and just a simple balance issue....
Also even if the wheel is balanced and it is an aftermarket wheel with a large hub pilot it can effect the balance without a spacer that fits between the wheel and hub.
- Check to see if the wheels are lug or hub centric
- See if they require hubcentric rings (spacers)
- Make sure you have the correct lug nuts (probably a bulge nut)
- Make sure all mating surfaces are clean
- make sure the rims are concentric and the tires dont display excessive runout (can be corrected to a point by match mounting)
- Make sure the rim/tire assembly is dynamically balanced (this can be achieved without resorting to mounting the weights on the outside - dont no let them static balance the wheels.
- See if th shop uses a pin-plate setup - this eliminates any problems between a hub or lug centric wheel ( the pin plates simulate the lug nuts in conjunction with the usual spring and cone centering fixture)
- Have them balanced on the metric setting to 5 gams or less. Do not accept a balance that is 10 grams (1/4 oz ) or more out.
- Make sure to ask if the balancer has been recently calibrated.
Bob....a good shop should cover those items when a car has a known issue.
Anything that causes the steering wheel to shake is commonly called a shimmy by most.....but the belt issue should be found with a road force balance.
Am I right?
Am I right?
Have you checked to see if the brake rotor retaining clips were removed to allow the wheels to sit flat against the rotors?
The OEM wheels have a recess for these clips but very few aftermarket wheels do.
If this is the case then it can cause just the "shimmy" that you describe.
![](https://sphotos.xx.fbcdn.net/hphotos-prn1/547091_10150967367102962_753471348_n.jpg)
![](https://sphotos.xx.fbcdn.net/hphotos-ash3/600135_10150967366782962_419353752_n.jpg)
I removed the clips from the front, but it didn't help the steering shake. The seats also vibrate on and off, so I know it's a balance issue. Just 900 miles on the car.... Here are some pics.
Will post results from tomorrow's tire shop visit.
i just had this same problem balanced all the tires, 20 inch and still did it, tire had excessive run out whole machine was shaking so i ordered new tires ill keep you informed, p.s front tires wernt to hot i think PO bought them off ebay
I had to constantly re-balance my 18 in Nitto 555 Extremes, there would always be a short range of about 10 mph where I got shimmy, just put on new Sumitomo HTZ R3's and all gone. Loved the Nitto grip, hated the high maintenance. Now I look for a performance tire that balances well as a primary consideration. What tires are you using?
those are the same tires i just installed only 20s there really quit and handle well 255/35/20 on the front and 275/35/20 rear Sumitomo HTZ R3's
those dont look near as bad as what i was thinking!
ssjbuu
8/28/15 08:55 AM
7/20/15 06:26 AM
