111k maintenance / misfire on cylinder 1 etc.
Old Mar 26, 2018 | 05:10 PM
mayhem37's Avatar
Awesome Supercharged * HPP 6-Speed Tms Member
Got a code (not sure of number!?), while getting onto the highway today. Engine
light blinking for a few minutes, then ... it was gone.
But, the local auto parts place tool said misfire on cylinder 1 ...
Most likely, spark plugs ... but that is the stores computer diagnosis.
Is there a go-to brand? They (plugs) seem to be "under" something horrible. So, I'd think
at this moment (pre-net-surf, pre you-tube education), it would be wise to change
the plugs with something very good, and also perhaps
the wires and coils as well?
Again, is there a go-to -- or a stay away from
experience anyone can advise?
Its not a race car, so factory quality parts are plenty good.
Thanks!
Old Mar 28, 2018 | 09:25 PM
kylerohde's Avatar
Thanks!
Nothing wrong with OEM Motorcraft then. Make sure you don't overtighten - remember it's an aluminum block. The factory torque setting for them is in in/lbs not ft/lbs.
Old Mar 29, 2018 | 06:06 AM
SpectreH's Avatar
Plugs would be the best thing to try. #1 misfire was probably P0301.
Old Apr 2, 2018 | 11:45 AM
mayhem37's Avatar
Thanks!
It has not happened again, but will get some plugs, and torque wrench (can't find the little one....)
and change some plugs.
The upper intake comes off, and there is a seal ... I should probably have one of those on hand,
just in case?
Old Apr 2, 2018 | 11:53 AM
mayhem37's Avatar
Thanks!
just in case?
Old Apr 2, 2018 | 01:24 PM
SpectreH's Avatar
Which engine do you have? No need to take any part of the intake off on a 5.0 to do plugs.
Old Apr 2, 2018 | 03:36 PM
mayhem37's Avatar
This is for the 3.7.
From videos ... the upper intake comes off pretty easily to provide access to the pass/side three
plugs/coils.
For the Performance Package, the car also has ...
engine cover BR3Z-6N041-C
strut tower brace AR3Z 16A200-A
Should get to this this week! (depending on parts arrival).
Old Apr 2, 2018 | 05:05 PM
mayhem37's Avatar
Fuel injectors! Anyone have a how-to for the 3.7L? Net-surf has not been very helpful. I could
swap these out too.
Thanks!
Old Apr 17, 2018 | 05:22 PM
mayhem37's Avatar
Anyone ..?
redsoxfan2010
1994-2004 V-6
21
Nov 12, 2016 11:24 AM
unas2k5
Oct 4, 2011 01:27 PM
Pinoy361
Aug 12, 2011 05:54 AM
ttbit
Oct 14, 2010 08:09 PM
kjdavis
1994-2004 V-8
Aug 16, 2010 06:16 AM
