S197 to S550 Steering Wheel Swap - The Complete Edition - Video Series
Old Oct 17, 2025 | 12:59 PM
Slonison's Avatar
{Step by Step} The Tms Accessorizer
Hey Guys,
Playlist List
I'm going to be starting a video series on swapping the S550 Steering Wheel into the S197 car WITH All of the switches working. This will include everything that is needed for making this work with a little more customization to come along with it.
Background: I started this project because I really really wanted to have a heated steering wheel in the car. I like the idea of having OEM parts and so I figured, what better time to swap it into the car than now. I don't particularly like the switch setup but it's a sacrifice I'm willing to make for the heating element. However, as many people who have attempted this have tried, getting the switches to actually work is another issue. This stops with me. I plan on getting every single switch to work including the clockspring assembly with the new handles.
My first video is below, and I will try to post them weekly as I make my way through this project. come along for the ride.
I'm not a youtuber, but I've found that videos are far easier to explain what I'm doing than simply dumping on a forum.
Here is my ever growing 200+ page Google Doc
https://docs.google.com/document/d/1...it?usp=sharing
Old Oct 17, 2025 | 01:51 PM
05stangkc's Avatar
Gave You a Sticky on This and Your RGB Thread Also Original S-550 Wheel Thread To Keep Them Close Together!
KC
Old Oct 17, 2025 | 06:06 PM
Slonison's Avatar
Part 2 Posted!
In this video! I describe the different steering wheels and how to pick one based on your needs.
Surprise! I went with multiple!
Old Oct 20, 2025 | 12:40 PM
Slonison's Avatar
Part 3: How the Switches Work
In this video I explain how the switches work in the steering wheel, the difference between the S197 and the S550 generally speaking, and the very basic outline of what we need to do to have a working set of switches.
Old Oct 22, 2025 | 04:02 PM
Slonison's Avatar
Part 4: How to set up the audio control switch
In this video, I explain how you want to redesign your audio switch circuit board to support the S197 output that you will want to be sending to the ACM through the harness.
Old Oct 24, 2025 | 06:45 AM
MadGT's Avatar
Legacy Tms Member
Wow, what an impressive project.
Old Oct 24, 2025 | 06:48 AM
Slonison's Avatar
Part 4b: Audio Control Desk Test
In this short video, I test the resistance of the Audio Control Switch to ensure that it is outputting the correct resistance.
Old Oct 24, 2025 | 01:56 PM
Slonison's Avatar
Part 5a: In this video, I explain how the S197 Information control switch works, and what we must do to make the S550 Information control switch mimic the S197 output
Old Oct 28, 2025 | 10:13 AM
Slonison's Avatar
Part 6a: In this video, I explain how the S550 Bluetooth Control Switch can be modified to act like the Bluetooth control switch from the S197 Mustang. Turns out, it's easier than the audio and info control.
Old Oct 28, 2025 | 01:15 PM
Slonison's Avatar
Part 6b: In this video, I test the S550 Bluetooth Switch Resistance Ladder
Old Oct 29, 2025 | 12:44 PM
Slonison's Avatar
Part 7a: In this video, I go over the design for the cruise control. I show you how to set up the switch without adaptive cruise control and how to set up the one with adaptive cruise control (though the gap up and gap down do not function)
Old Oct 29, 2025 | 02:51 PM
Slonison's Avatar
Part 7b: In this video, I test the S550 Cruise Control Switch Resistance Ladder
Old Oct 30, 2025 | 04:24 PM
Slonison's Avatar
Part 8: In this video, I walk you through making the harness that is compatible with the s197 clockspring.
Old Nov 4, 2025 | 01:33 PM
Slonison's Avatar
Part 9: In this video, I dry fit the steering wheel to test out the installation.
Old Nov 6, 2025 | 05:54 PM
Slonison's Avatar
Part 10: In this video, I explain the difference in the airbag connectors between the S197 and S550 and demonstrate how to repin them.
Old Nov 7, 2025 | 02:58 PM
Slonison's Avatar
Part 11: In this video, I show the fully installed S550 in the S197 mustang with a fully functioning switch set
Old Nov 8, 2025 | 08:43 PM
Slonison's Avatar
Part 12: In this video, I compare the differences between the S197 and S550 Clockspring and Assembly, and teardown the S550 Clockspring
Old Nov 10, 2025 | 08:26 AM
Slonison's Avatar
Part 13: In this video, I discuss the functionality of the S550 heated steering wheel and how to make it work in the context of the S197
Old Nov 12, 2025 | 02:59 PM
Slonison's Avatar
Part 14: In this video, I address the Turn Signal / High Beams controls for the S550 and how to make it work for the S197.
Old Nov 13, 2025 | 04:43 PM
Slonison's Avatar
Part 14b: In this video, I test the Turn Signal / High Beams controls Note: I solved the sensitivity of the always on, it was a loose wire.
