-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Retrofitting the 4.2 LCD Track Apps cluster (https://themustangsource.com/forums/f803/retrofitting-4-2-lcd-track-apps-cluster-529167/)
dmhines Nov 5, 2014 11:30 AM
Track Apps will appear in your cluster .. but it will not work without the new ABS module. Pretty sure that was thoroughly discussed in this thread. It was also mentioned early in this thread that the 2012 select buttons can control the menu.
Onefastmf Nov 9, 2014 10:33 AM
Just so I'm 100%, I have a base 14 and putting in a Premium cluster does not require module programming? No as build has to be done also?
Onefastmf Nov 9, 2014 10:58 AM
I cannot gets pats to work, I did the earase of the keys and then when I get to the programming keys, it says tune key off, turn new key to on for 6 and then do same for next key, when I do that it says two keys have been programmed but also says to many keys cycles and security access lost and says to go though process again. Not sure what I'm doing wrong, please help.
LEXiiON Nov 9, 2014 11:23 AM
Once you programmed the two keys, exit the PATS menu and re-enter it. Then do the parameter reset option, and you successfully done the PATS.
LEXiiON
Onefastmf Nov 9, 2014 07:12 PM
All good thanks:D
manlaw38 Jan 3, 2015 01:13 PM
will this work on a 2011 3.7 v6 with preim poney package?
ajpturbo Feb 14, 2015 11:30 PM
Anyone notice the link for as built data isn't working?
dmhines Feb 15, 2015 06:08 AM
Yes. Ford shutdown the build data site. Need ID and password now. Parties over. :(
zeroaviation Feb 15, 2015 06:57 AM
EDIT: If anybody needs ASBUILT PM me the VIN you need the ASBUILT for. I will only get it for established members of this site.
-Matt
jim010 Feb 18, 2015 06:03 PM
I always knew Ford would close the door on us doing these sorts of mods. I think they closed it on us with the new VCM version as well.
zeroaviation Feb 18, 2015 06:43 PM
It won't take time for someone to make a work around.... Give the chinese a little time lol
-Matt
ajpturbo Feb 18, 2015 10:05 PM
What do you mean?
zeroaviation Mar 2, 2015 09:40 AM
Does anyone have a part number for the pins used in the connectors for the clockspring or the switch?
I know blueeyedsnake (sal) found them, but hes banned from most forums now. So I cant ask him :/
-Matt
LEXiiON Mar 2, 2015 10:21 AM
I have his cell # if you need it.
I just been to the as built site and got a as built version of a car. So it still works for me without login.
LEXiiON
dmhines Mar 2, 2015 10:21 AM
Never saw a part # .. I know Jim010 was sourcing them from old wiring harnesses.
LEXiiON Mar 2, 2015 10:30 AM
Another update: You have to go manually into the link. Start the at motorcraftservice.com, then Quick Guides, then as built. Works fine.
LEXiiON
dmhines Mar 2, 2015 11:41 AM
Thanks! I had been using the old direct link .. but going in through motorcraftservice does still work ...
zeroaviation Mar 2, 2015 02:57 PM
LEXiiON
I texted him, I doubt I get a reply sadly :/ If anybody has this info, would be greatly appreciated.
This is good news!
-Matt
jim010 Mar 3, 2015 02:09 PM
You need males and females, I assume? I can certainly get you some from my old harnesses as Dan said - but as for ordering them, that would take some research.
zeroaviation Mar 4, 2015 09:14 AM
I have some from my old harness as well (once i find my old harness lol).
I was hoping to get them so I can order them... Will report back what I find once I get my car out of storage this weekend.
-Matt
