Put Plastic Film over Non-Nav Radio Display - Now bubbling!
Old Jul 18, 2011 | 08:05 PM
Double-EDad's Avatar
Unhappy Put Plastic Film over Non-Nav Radio Display - Now bubbling!
So I bought this screen protector plastic (originally packaged for an iPad) and I am not very craft-y. But I did my best to make a template, then I cut out the right size from the plastic sheet (I have maybe enough to do 2 more).
I applied the film last night and smoothed ALL the bubbles out and it was looking GOOD - not one scratch!! Then today I got in the car to go home after work, and because it had sat in the sun all day (I am guessing), there was a dime-sized bubble under the plastic!!
So you guys that have worked with this film much on the non-nav display, what are the key "tricks"? How can I salvage this? I hate wasting time on fussy/fiddly little tedious stuff like this!
Old Jul 18, 2011 | 08:14 PM
bones302's Avatar
you will likely need to buy a special film made specifically for your nav. it will be made out of a thicker film.
Old Jul 18, 2011 | 08:58 PM
dmhines's Avatar
You talking about the sync display? you don't touch it so why you covering it?
Old Jul 18, 2011 | 09:20 PM
jaybertx's Avatar
The thing is made from the most fragile plastic on earth. Cleaning it with a micro fiber will scratch the hell out of it and it's just annoying.
Old Jul 19, 2011 | 06:43 AM
MyStang2010GB's Avatar
^^^ That ^^^
Old Jul 19, 2011 | 08:11 PM
EXACTLY. This is my second 5.0 in 12 months, so THIS time around I did not remove the radio/sync display's factory plastic covering until I got ahold of this iPad plastic cover. So I was able put the new film on top of a virginal unscratched display, and that's really saying something, thanks to the above-stated fact.
But I fail to see where a bubble looks much better than scratches, except for the fact I guess I could peel this thing off and try again. But then if I do I prolly have to wipe it down after peeling off my 1st attempt, and then...
I hate this crap.
Old Jul 19, 2011 | 08:14 PM
dmhines's Avatar
Perhaps a strip of clear packing tape would work better. Are you removing the screen from the car before installing the cover?
Old Jul 19, 2011 | 08:19 PM
No, and I've not really seen a good how-to on TMS. Maybe it's supposed to just be obvious, but I have no instincts in this dept.
To the poster above who said to get one made for the display - Please tell me where I could find such a thing, I'd get it in a heartbeat! I am 99.999% such a thing doesn't exist because (a) the display isn't intended to be touched anyway, and (b) there are too few of us out there that care about the propensity for scratches on the non-nav display to do anything about it.
Everytime I've read of someone doing this trick, they used a screen protector made for the iPad and then (I guess) cut it to fit. Maybe I need to remove the dash panel so I can get at the naked display. Good idea, dmhines, but I'm not sure how to do that.
Old Jul 19, 2011 | 08:27 PM
dmhines's Avatar
Grab the console by cup holders and pull up. Upper console will pop out. Disconnect wires and move it out of way.
Remove two small bolts at bottom of center stack. Pull on the center stack and it will pop out radio and climate controls go with it. Disconnect the cable and put it aside.
You can now remove display.
Old Jul 20, 2011 | 09:36 AM
bones302's Avatar
i thought you had the nav, but either way, you can pop off the front dash plate to get at the whole radio display in order to get a cleaner install. I think yours is bubbling because you used a thinner film made for a touchscreen device.
I would call someone like zagg.com in order to cut you a special piece. just tell them it's for a car radio display.
Old Jul 20, 2011 | 10:23 PM
Adam's Avatar
Yeah, you really need to remove the bezel. That's what I did, and my invisibleshield still looks flawless.
Old Jul 21, 2011 | 08:01 PM
I'm on it. As soon as the temperature in my garage drops back into the double digits...
Old Aug 30, 2011 | 08:34 PM
Banjostang's Avatar
I scratched mine the first day by stupidly trying to wipe dust off it with a microfiber cloth. Put an iPad protector on it which looked ok (hid the scratches some).
I found this post on AFM where a guy made glass replacements for the display. Cost $15 including shipping. Best $15 I have spent. Install took 15 minutes and now it looks like it should have when it came from the factory.
Here's the link to the AFM post.
Can't say enough good things about it or the guy that makes it.
http://www.allfordmustangs.com/forum...lay-glass.html
Old Aug 31, 2011 | 09:39 AM
AWESOME!!! Gotta me one of those ASAP!! Thanks man
Old Sep 3, 2011 | 05:13 PM
jmpancoast's Avatar
I just did this and second how easy it is and what a great job he did making these display covers up. Ordered it and had it in two days later.
Old Sep 8, 2011 | 03:50 PM
Adam's Avatar
I put Invisible shield over mine but I'd definitely prefer glass. Putting in my order now!
Old Sep 12, 2011 | 07:21 PM
Adam's Avatar
I just replaced my plastic screen with glass from that other thread. Looks amazing and only took 15 mins to swap out.
Attached Thumbnails Put Plastic Film over Non-Nav Radio Display - Now bubbling!-afterscreen.jpg
Old Sep 17, 2011 | 02:36 AM
Digital_Synapse's Avatar
that glass looks awesome. I wish I knew how to do that.
Old Sep 17, 2011 | 01:35 PM
Banjostang's Avatar
It really is easy. Remove 2 screws, pop off the two panels, plastic radio display cover pops off with a jeweler's screwdriver, put the glass cover in and pop the cover's back on. Takes 15 minutes.
Visit the thread on AMF http://www.allfordmustangs.com/forum...lay-glass.html
There is plenty of how-to information.
Old Sep 17, 2011 | 03:39 PM
thanks
JonsMustang
Mar 5, 2016 05:44 PM
dblhelx
Oct 6, 2015 08:08 PM
TMDM
Sep 24, 2015 07:00 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
