New taller shift knob
Old Dec 16, 2011 | 09:48 AM
Barton Industries's Avatar
New taller shift ****
Here is a new product that we just released. It will raise the shift **** 1.5 inches, giving you more leverage for smoother shifts.
This really helps with those who are having the grinding and notchy trans issues. Not to mention you can actually use the cup holders now.
It works with the stock shifter or the Barton shifter.
This shift **** extender will only work with the shift boots that came with the leather wrapped shift *****, this will not work for those who have the aluminum ball style shift ****.
As always, install it, if you don't like it send it back for a full refund.
Raise your shift **** 1.5 inches for more leverage and a smoother shift.
Machined from 6061 T6 Billet Aluminum and Nickel/ Chrome plated.
Can be used with the factory shifter or the BARTON shifter.
Multiple shift **** options.
This is the first option for those who want to get the shift **** closer to the wheel for faster shifting on the track without having to replace the whole shifter.
www.bartonindustries.com
Old Dec 16, 2011 | 11:14 AM
Ltngdrvr's Avatar
There's something that a lot of people have been wanting.
Old Dec 16, 2011 | 11:45 AM
theACE's Avatar
this I like.
Old Dec 17, 2011 | 01:34 AM
ksguy73's Avatar
We need an option like this for the 2010's too! Any idea if this will work for one with a Grabber Pony shift ****?
Old Dec 17, 2011 | 06:05 AM
Thomas S's Avatar
Got any pics of it installed?
Old Dec 17, 2011 | 09:38 AM
908ssp's Avatar
I have been a proponent of raising the shift **** for ages. The short throw shifters work much better when the ***** is higher up. The throw length is about the same as stock but the feel is improved the ergonomics of having the shifter closer to the wheel and your elbow not dragging on the center counsel is a huge improvement. I made my own lever and used the old Ford Racing **** for my shifter.
Old Dec 17, 2011 | 10:09 AM
JimmyM's Avatar
any plans to release the extender in black?
Old Dec 17, 2011 | 09:34 PM
2 Go Snake's Avatar
Smile
I have been wanting Ford to produce a taller shifter for a long time. The Barton shifter sure is a fine piece. I will have to get one. Actually, I would even prefer a two inch longer shift lever.
Old Dec 17, 2011 | 09:42 PM
2 Go Snake's Avatar
Question
I have a question for you all at Barton Industries. What would I have to modify on your shift lever to allow the use of the aluminum shift **** ? Would I just have to add a threaded sleeve to the top that would fit an aluminum **** ?
Old Dec 18, 2011 | 10:12 PM
908ssp's Avatar
"This shift **** extender will only work with the shift boots that came with the leather wrapped shift *****, this will not work for those who have the aluminum ball style shift ****."
If you're referring to this line they are saying the boot not the **** won't work. Any **** with the same thread will work with the extender.
Old Dec 19, 2011 | 10:34 AM
2 Go Snake's Avatar
Thanks for the clarification. I thought maybe there was a difference in how the ***** were attached. I sure like the Barton shift lever and would like to have one in my next Mustang.
Old Dec 20, 2011 | 08:34 AM
Ksguy73- This will NOT work on the 2010, the shifter is different so the spacer would not sit like its supposed to and the under side of the boot is different. It should work with the grabberpony **** because they get there ***** from the same place we get ours. The only issue that could pop up is if they have there inserts recessed further than ours. The jam nut we use is .225 thick so if they recess the insert .200 or more than you couldn't get a wrench on the jam nut.
JimmyM- Yeah, we can do them in black. The only problem is, we have a bunch already done and they are already chromed so it will have to be from the next batch. Tell everybody to hurry up and by these so I can get you a black one made. Haha
2 Go Snake- Im going to also make one for the people who have the 401a interior (aluminum ball) Im just not sure when it will be. But you will not be able to reuse your stock ****. The aluminum ball from ford does not separate from the collar that comes off of it.
Old Dec 20, 2011 | 06:58 PM
Ltngdrvr's Avatar
Just cut the **** off above the collar...
Old Dec 22, 2011 | 03:33 PM
MPETE's Avatar
I DESPERATELY need this for the 05-09 style. I hate how low the shifter sits and hvae been contemplating getting a Hurst simply because of the added height it gives
Old Dec 22, 2011 | 03:43 PM
Ltngdrvr's Avatar
The thread size is the same, you could probably make the extension work, not the **** though unless you want the wrong pattern.
Old Dec 22, 2011 | 06:10 PM
05-1947's Avatar
So this will work with the Premium 400A optioned cars?
Old Dec 26, 2011 | 03:45 PM
RaceRed50's Avatar
I'm sorry, but your prices are outrageous, even the adapter alone with out the ball. 75? You had me sold til I saw the price. I can get the Boss shifter ball and the adapter for $50. Good luck...........
Old Dec 31, 2011 | 08:56 PM
If you look at our normal adapter and ball, you will see the price is the same as the boss one you are referring to and ours are chrome plated which adds $7 of overhead per piece. There is a lot more to the taller adapter than just turning a piece of aluminum and putting a threaded hole through it, and yes the price does reflect this. If I could make and sell these for $10 I would, but I can't even buy the material or have it finished chromed for that.
Our prices might not be the cheapest out there, but its for good reason.
05-1947 - Yes this will work with your car.
Old Jan 1, 2012 | 09:26 AM
JCStang's Avatar
To install just the extender and new shift **** ( not the new shifter), is it just a matter of removing the current one and adding the new one without removing the boot and console or does it also require all of the initial steps reflected in the 7:26 video on your website? I have a base v6 with performance package and just wonder if this is a quick replacement or a multi step project?
Old Jan 1, 2012 | 02:04 PM
Its very simple, you do have to pop up the center trim to put the spacer under the shift boot, but you do NOT have to remove the rubber dust boot that goes around the shifter. It takes me about 2 minutes to put one in.
Remove factory shift ****.
Pop up console and put the spacer under the shift boot.
Thread down the chrome adapter and tighten.
Thread down shift ****.
