Install Complete!
Old Feb 11, 2015 | 09:51 PM
05PRMTX's Avatar
Install Complete!
So my original build thread seems to have gotten buried. so I figured I would post everything in a new one. I still have some deadening and wire clean up to do, but its all in and working.
Here's the equipment again:
HU: Pioneer AVH-X5700BHS
Speakers: Soundstream Exact 5.2s(coax) & 5.3s(comp. set)
Subwoofer: MTX TR7512
Amps: 4CH. MTX TA7804, Mono: MTX TA5601.
HU
1/0 Power and Ground
Speaker wire
Running the power wire:
Buttoned back up
RCAs
Doors
Sub
Rear Deck
Amps(all I have at the moment). Will update
Old Feb 11, 2015 | 10:16 PM
Jazzman442's Avatar
Nice Install. I love the car and the way you did the dash. Did you make the sub box or are you doing an infinite baffle?
Old Feb 12, 2015 | 07:12 AM
05PRMTX's Avatar
Thank you! I'm very happy with the way the dash turned out. For the box, Its a sealed box built to fit by these guys: http://www.zenclosures.com/Mustang-S...angtype2ar.htm
Old Feb 13, 2015 | 10:16 AM
firstang001's Avatar
Very Nice install!!
Did you have Sync in your car?
Old Feb 14, 2015 | 09:17 AM
clucas's Avatar
Love the install and how simple the trunk looks with that zen enclosure. Did you put anything on the power wire going to the battery to protect it? Any wire loom or expandable sleeping to prevent any damage to the wire jacket?
Old Feb 15, 2015 | 04:38 PM
05PRMTX's Avatar
Originally Posted by firstang001
Very Nice install!!
Thank You! No, I didn't have sync. Just the base 4 speaker stereo.
Old Feb 15, 2015 | 04:41 PM
05PRMTX's Avatar
Thank you, I couldn't have asked for a better fit with the enclosure. Zen enclosures does a fantastic job. For the power wire. I've got the standard black plastic to put over it. Wire tied it along its path so it wont move. Other than that I think it should be ok. It doesn't pass by anything that would interfere with it. Its far enough from the engine that heat shouldn't be an issue either.
Old Feb 15, 2015 | 06:07 PM
clucas's Avatar
Good, I'm glad to hear you protected the wire. I just didn't see any in the photos.
Old Feb 18, 2015 | 01:18 PM
Oh okay!! Its the same with me. I had tried to go a different route and I not very impressed with what I did.
Instead of having an actual amp powering I have got a power pack pushing four speakers . And I still have the stock head unit which is awful. I eventually want to have 2 amps powering a Sub and 4 speakers. Not sure If I should still keep the stock head unit or go after market.
So when you went with after market head unit. Did you loose any functionality of the stock face plate and steering wheel?
Old Feb 18, 2015 | 02:33 PM
05PRMTX's Avatar
I know its expensive, but go aftermarket. If you are wanting a sub its almost a must. You won't regret it. I'm not surprised you are disappointed by the power pack, those just don't do enough and you still have the problem of a weak signal from that awful stock HU. If you want to keep the stock headunit you can always get a processor. Even look at a nice 5ch amp to keep it down to just one amp.
Old Feb 19, 2015 | 07:57 AM
What does a Processor do? Can you post a link of a product so that I can research further on this?
Also with after market head unit. Did you loose any functionality of the stock face plate and steering wheel?
Old Feb 19, 2015 | 09:11 AM
tom281's Avatar
Processor is almost a must if you want to keep the stock head unit and have good to great sound quality. Audio Control, JBL, JL Audio, Alpine all make great processors. Not cheap but neither is a new head unit and dash relo kit.
BTW nice job OP!
Old Feb 20, 2015 | 06:05 PM
05PRMTX's Avatar
Well I didn't have steering wheel controls or anything extra to begin with. But if anything I gained functionality. The touchscreen is very easy to use, much easier than the stock controls IMO. Then the radio is all Bluetooth, so I gained quite a bit there. As far as steering wheel controls though, if you have them and want to keep them they make adapters for the wiring harness, so don't worry about that.
Here is an example of one of the processors
http://www.rockfordfosgate.com/produ...tails/3sixty.3
Old Feb 20, 2015 | 06:06 PM
05PRMTX's Avatar
BTW nice job OP!
Thank you! Pretty pleased so far, could do with some more power though lol. Going to do the big three as soon as the wires come, then a bigger alt may be in store down the road.
Old Feb 24, 2015 | 08:47 AM
Thank you!! Will keep an eye on this..
Old Feb 24, 2015 | 10:41 AM
CiniZter's Avatar
look perfect as OEM.
Old Feb 25, 2015 | 02:51 PM
05PRMTX's Avatar
Thanks. I was trying to keep it as OEM looking and unassuming as possible. Pretty happy with the end result.
Old Mar 10, 2015 | 03:28 PM
ant35447's Avatar
Looks really nice, just curious, what dash kit and tweeters did u go with?
Old Mar 11, 2015 | 08:35 AM
05PRMTX's Avatar
Thank you. This is the dash kit:
Amazon.com : Scosche Dash Kit for 2010 Ford Mustang Double Din and Din with Pocket : Vehicle Audio Video Power Adapters : Car Electronics Amazon.com : Scosche Dash Kit for 2010 Ford Mustang Double Din and Din with Pocket : Vehicle Audio Video Power Adapters : Car Electronics
As far as the tweeters go they are 1" dome and part of my component set. They are some old school soundstream exact 5.3s. They were soundstreams top of the line set in the late 90s beofre they got bought out by some over seas company.
Old Mar 11, 2015 | 08:47 AM
tom281's Avatar
Old Soundstream rocks I sold it for years until about 98/99 then it went to the dump. I have two old Reference 700s amps that I'll be using in my build. I check eBay constantly for old Soundstream and old Orion HCCA equipment lol.
