I know we keep talking about speakers
But god the stock speakers are aweful. Things that I listen to at my computer (with my M-Audio studio monitors) sound nothing like how they do in the car. Old Santana is a good example. I can hear everything in the drums (without brightness) and the soft hum of the organ and the smooth mids of the guitar tracks, that just isn't in the Mustang. I get the lows, (and there is really good seperation in the Mustang) but anything past the mid bass and subwoofer is just muffled mud. I think the biggest issue is the equalizer. I can only make the sound BRIGHT, but I can't pull up the mids at all. The mids are somehow affected by the bass adjustment, but then it's overwhelmingly bassy.
I am one of those people that sort of likes having the OE radio and integration in there, but now I am clearly seeing the need for some sort of inline equalizer along with speaker upgrades.
FWIW, I have the Shaker Pro. It is good enough and adequate, but I do actually take an interest in my music and how it sounds. I prefer a real, accurate representation. (Stuff like organs and strings and piano are often where you can tell if speakers suck, because they fail to accurately reproduce their sounds)
Look into an Audison bit ten (or bit one), or the JBL MS-8. They are factory integration units that give you multiple band EQs for every channel and the MS-8 combines the processor with an 8ch amp too.
This will sound weird but equalization is normally only real a solution when proper equipment can't be selected. Even a parametric eq will still pull other frequencies slightly out of wack. Generally, of is preferred to keep the setting flat and correct your equipment. That way you hear the music the way it was intended.
If you want to improve your system, even a speaker upgrade may help. Something with a high sensitivity to work with the factory amp.
The "right" way would be an amp and better speakers. I would try speakers and see what you think.
laser, those are stupidly expensive!
Mr. V -- you are right, the general want would actually be a flat EQ.. that is true. I find that even with my studio monitors I boost the mids a bit, and the higher end just to bring out drums. I generally use the EQ as a tool to bring out the presence of instruments and voices. If you have good reproduction, you don't need to. The separation will be strong enough that you can close your eyes and clearly hear every instrument. every bit.
Originally Posted by fgibbs
So all you need would be a MS-8 and that would allow you to add amps and new speakers and keep all the OEM intregration or do I need some other parts for the intregration?
And processors aren't any more expensive than a CAI and tune. Gimme a break. People are so willing to pay top dollar for little gains on performance parts, but when it comes to their sound, instantly everyone becomes a cheapskate. Yes, you want a flat eq - in an optimal listening environment, which a car is NOT. Reflections and people's tastes vary widely. A processor gives you the flexibility to tailor the sound to your own tastes and your car. Just swapping the speakers is a crapshoot - you're still limited to the factory eq and bass/treble adjustments, and you don't know if they a) work for your ears, b) work well with your stock tuning, until they're installed.
The proper way is to do speakers AND amps AND a processor, but most of you aren't willing to pay to play for all of that. That's why I suggest just the processor, because you have a higher chance of tailoring your factory system to where you're happy with it, versus trial and error on buying, installing and uninstalling speaker sets that you can't try out until they're in your doors.
Good advice...I plan on running a 3 way active setup up front and a sub out back with the JBL MS-8 pushing the tweets, JL Audio 600/4 HD and a JL 750/1 HD. I like the HD amps since they are small and light for sure. I am still undecided on the tweets, midrange, midbass...any suggestions? Sorry for the thread jack DIVA!!
I hope to install all of this myself...but will be a challenge since this is still my first active setup. I prefer a nice mellow true sound, however I listen mostly to rock, classic rock, alternative, heavy rock. Very rarely listen to anything else but like to have an option for it to sound good if I do. I certainly don't want to go overboard on the budget end but would be willing to spend 150-250 on each component I guess. As for deadening I have already ordered that first since I realize how important it is. I ordered from second skin audio some damplifier and some Luxury Liner pro MLV. So that along with some ensolite from rammat I should be good on deadening. However, I am still trying to figure out frequency ranges.
Agreed. I had a crappy system in my 2012 Boss302 and lived with it. I figure somewhere down the line in the near future I will upgrade the entire system. I'm just waiting for a dash kit that doesn't look like shyte first. So far no such kit exist. I'll wait for a bit longer. The car is a weekend play toy so I can deal with it for now.
laser, I appreciate all the help you have given me. I will simply start with 5.25" components and see what happens. I'll also see how my fiancee likes it. In the end though, I am not opposed to going with the Bit-1 and trying other things.. For now, though, I mean... hell... I ordered my car. I wanted the Shaker Pro. I might as well see how I can work with it before abandoning it.
I also knew it was the only way I'd be able to sneak a subwoofer in there. My fiancee refused to drive my GTO (it was cammed and even though it had similar power to the Mustang, it was much more "wild") and she hated the sub in the trunk.
Also, how was the response of your sub in the GTO? I know those things have horrible trunk designs with the gas tank and trunk being sealed off from the cabin like a convertible.
Comp Cams XR281 cam (228/230 .571/.573 lift on 112LSA)
Stainless Works Long Tubes
SLP 160* Thermostat
MSD Wires
Monster Stage 3 Clutch
Lightweight Flywheel
Ported intake and Throttlebody
Home made CAI (used left overs from JLT '06 Mustang CAI)
GM Motorsports "Street" Shifter
Lou's Short Stick Arm with Hurst ball.
35% window tint
19" G8 GT wheels
RK Sport Spoiler
2006 GTO Taillights
DDM 55w 4500k HIDs in headlights
DDM 35w 4500k HIDs in foglights
Klearz Black backed sidemarkers
Custom Catback, offroad mids, x-pipe, flowmaster american thunder mufflers
Among other mods............
Personal best in the 1/4 mile on street tires was a 12.48@118mph, nearly touched 11's on drag radials. 411rwhp/401tq
Owned it for Seven Years, from mile 4 to somewhere north of 85k.
lol
