help with replacing 2012 sub amp
I just purchased a 2012 with the shaker 500 system and nav. I ordered a couple shelby kicker speakers as they are plug and play. I'm aware i need to change the amp as well.
I'm looking for a fairly plug and play solution.
I did some searching online, and several posts/sites mentioned using a sony small amp. But it's not plug and play.
Should i get a different amp? or just find the right harness? The amp is only for the door subs.
ideally, i hope to get 2 harnesses for this to work --- 1 from head unit to amp, 1 from amp to door speakers. Thanks!
did you ever find a solution. I would like to know also.
cnaimo
'10-14 Interior and Audio
18
Jan 23, 2012 09:01 AM
