GT500 shift boot
Old Oct 14, 2010 | 04:33 PM
Overboost's Avatar
****? I thought you got the boot?
I did, my bad. Fixed my previous post.
I want the Boss 302 **** when it comes out. I think the two together will be a nice touch to differentiate my car from the stock GT.
Old Oct 14, 2010 | 07:55 PM
stangfoeva's Avatar
MOTM Committee Member
yeah that will look good
Old Oct 18, 2010 | 05:29 PM
Overboost's Avatar
Got this tonight, and after trying, it won't fit over the shift ****. The plastic collar won't slip all the way down over the shift ****, so this is a lost project. Don't buy one and be out $40 like I was.
Old Oct 19, 2010 | 12:07 AM
Adam's Avatar
I'm confused. What do you mean it won't fit over the shift ****? You unscrewed your 401A shift **** and the plastic collar won't fit over the threaded shaft? The base of the shift **** in the picture you posted looks to be the same size as 401A but pictures can be deceiving. You could try removing the collar to give more slack.
Old Oct 19, 2010 | 04:00 AM
Overboost's Avatar
Yes, you're correct. It appears the collar of the shift boot has a smaller ID than the threaded shaft OD. There is also a "spike" coming down off the collar on the GT500 boot that won't let it fully seat (which I know can be taken off). The collar is glued in from the bottom so it can't be removed from the boot. I'm going to take some measurements and see what I can do to try and get this to fit.
Old Oct 21, 2010 | 08:48 AM
Overboost's Avatar
UPDATE:
I got this to work. When I took measurements of the shifter shaft and the plastic collar on the new boot, they were very close. Found some plastic "boogers" which appear to be from manufacturing. I cleaned the collar out with a knife and that allowed it to slide down freely. There is one ear that sticks out from the inside of the GT500 boot, and that needs to be removed for the boot to sit flush like the stock 401A boot, which I did with a pair of side cutters and a file. You could use a Dremel and accomplish the same. Once that was done, it was simply a matter of snapping out the old boot and putting the new one in its place. Push the collar down to the bottom of the shifter assembly, then thread the 401A **** right over it, and you're done.
Pics of the finished product:
Old Oct 21, 2010 | 09:33 AM
Automagically's Avatar
do it. its worth 40 bucks to see if you like it
I agree!
Edit: Whoops, I'm late to the party! Looks good. I like the GT500 Boot, with or without the matching steering wheel. What would look nice is white stitching on the regular leather steering wheel to match the 401A package. A la, Motorsport style, that would certainly win me over on the 401A package. As if the **** isn't enough.
Let us know if you find out anything about the Boss shift *****. (Once again, just stating the obvious)
Old Oct 21, 2010 | 09:48 AM
Overboost's Avatar
It's not a 100% match to the cashmere stitching (this is truly white) but it looks good and adds a little contrast to the shifter boot, which is what I was looking for.
Good thing, this gives any 400A people another option to change the look, and for 401A people they can go with something different as well.
As for the Boss ****, we won't know much until 2012 parts and models start hitting the showrooms. I'll keep you all posted when I find out more.
Old Oct 26, 2010 | 02:53 PM
i3arracuda's Avatar
I like the contrast stitching on the boot, even without the GT500 wheel to match. I'd really like to see a GT500 shift **** with the proper pattern for the '11 GT trans.
Old Mar 8, 2011 | 06:16 AM
Overboost's Avatar
I see Parts Cheap has taken it off their site. Part number for reference is AR3Z-7277-AA.
Gigantor
May 11, 2023 07:31 PM
Jul 8, 2016 08:53 AM
GLOCKer
Sep 28, 2015 05:20 PM
