-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Custom Interior Lighting (https://themustangsource.com/forums/f803/custom-interior-lighting-501412/)
bill0754 Oct 25, 2011 06:09 PM
2 Attachment(s)
Since all my perfomance and Exterior Mods are done now, I decided to add some custom lighting to the interior for the shows. I go to at least 2 shows a week, so a little flash makes it fun for everyone. I don't have a tri-pod yet, so the photos are not perfect.
postalworker Oct 25, 2011 07:31 PM
too Halloween for my taste, but hey, it's your car...
bill0754 Oct 26, 2011 06:37 AM
The lights are acutally red, but for some reason photograph as orange. They are also on a seperate switch, so they are only on at car shows.
hogasswild Oct 26, 2011 06:03 PM
That's the first time I've noticed that the shape of our dash looks like the back of the new Charger.
chronos Oct 26, 2011 08:54 PM
I like it. How did you get the lights around the edge of the dash? Is it a LED light rope or something like that? Day picks close up so we can see what you did would be great. I know I want to see it.
stupidgenius36 Oct 26, 2011 09:00 PM
Wow, that's pretty cool. Reminds me of Tron. I'd like to see some day pics as well. Can you change the color, or are they only red?
bill0754 Oct 27, 2011 07:49 AM
Dash Lights
4 Attachment(s)
Thanks for the compliments. First, they are actually Neon. I purchased them from Glow Smart. The link, in case anyone is interested is:
http://www.glow-smart.com/shop/index...te=common/home
They offer many colors, but each set is just one color. It is not changable.
As for install, it was super easy. Since the dash is soft touch, the tube actually can be just push into the dash between the soft part and the metal trim. I used a dash of clear silicone around the bottom of the center vents as it didn't have enough room to push the tube in. I ran the power down under the steering column and then into the center console. I obtained power from the powerpoint in the console.
I also added 2 LED light strips under the dash to light up the footwells as well. Since the factory ambient lights can't be turned on without the car lights on, this was a perfect solution to augmenting the upper dash lights. Plus, it REALLY lights up the foot wells!
Also, this is completely reversible with no damage to the car! So it adds a little color to the otherwise black interior with the option of easy removal.
And, you will also see the new OEM aluminum trim I had made for the center stack/console. Except that it's just a bit shinier, it is a perfect match!
Here is the Dash in the day, plus some closeups. I chose red because of the red stripe on my car.
Kinyodas Oct 27, 2011 09:36 AM
They even look good in the daytime - like a nice trim accent - I *might* be interested in something like that.
I'm a bit confused - exactly which items did you get? I'm not finding it in the neon section.
chronos Oct 27, 2011 09:36 AM
Kudos to you, I like it. It kinda looks like something I have seen around before that was a cloth edging (welting maybe, forget the proper term) that you could just push in around the edges of the dash or door trim. This is cooler though because you can light it up. I would suggest adding it around your door trim also if you have dark paneled doors. If you have the red door insert then it would be pointless. Lighted doors would be cool for shows too. Gotta post pics if you do it.
bill0754 Oct 27, 2011 10:07 AM
Under the "Cars & Trucks" section, it is the "EL Wire" product.
I have considered doing it around the door insert, but since the EL wire won't stay in place, it would require a adhesive. And it would involve removing the panels and drilling a hole. So, for now, I am staying away from the doors. But the LED's under the dash reflect really nicely on the aluminum panels on the door, so that helps
Scruffy281 Oct 27, 2011 10:48 AM
It actually looks REALLY good in the day time. Great job on doing something out of the ordinary, and perfect for shows or just cruising.
What lights are you using under the dash?
bill0754 Oct 27, 2011 11:35 AM
Just regular 12" LED strip lights. They self stick, and are low powered, so it was a very easy install
Planeswalker Oct 27, 2011 06:26 PM
What length did you use for the dash? Is it trimmable or do you just tuck away the extra?
bill0754 Oct 27, 2011 06:31 PM
I bought the 10' and it is trimable, so start from the power side first, then cut off any extra with a scissors.
Scruffy281 Oct 28, 2011 11:08 AM
Where did you get them?
Kona Blur Oct 28, 2011 11:36 AM
He put a link in his post...
Scruffy281 Oct 28, 2011 01:55 PM
That's where he got the neons. I don't see the 12" strips under the dash he is talking about. He called them 'regular LED strips'.
bill0754 Oct 28, 2011 03:16 PM
Hi,
The 12 inch LED strips are available at Autozone.
http://www.autozone.com/autozone/acc...uestid=2924676
It says 24" on the box, but it is actually 2 12" strips
Big Poppa Oct 30, 2011 01:03 PM
very nice, I might do something like this as well.
JEdwards001 Jan 13, 2012 09:49 PM
1 Attachment(s)
Awesome idea with the el wire!!! I added a little blue and love it!!!
