clean 2013 gt500 SQL install
stumbled upon this clean install today. looks like they used kenwood amps, an audison bit 10 processor and audiomobile elite subs:
http://srqcustoms.com/Gallery/ford-mustang-gt500/
Very nicely done! I like the custom-welded amp rack and the power distribution block, however, I don't like the way it looks just floating in the spare tire well. Just my opinion, of course - functionally it should be just fine. I guess they figure since it's covered by the main trunk carpet, who cares what it looks like.
I never used Kenwood Excelon amps - any opinion of them?
yeah, it looks like they have brackets to make sure it's braced properly but usually you'd see some type of sound deadening at the very least. the owner probably didn't want to add more weight i'd assume plus i think the vibrations come more from the trunk lid than anywhere else back there. i'm just fascinated with how clean the trunk looks.
The sub box is a thing of beauty though if you don't mind giving up the trunk space. Personally I'm not a huge bass guy, which is why I went with a JL Stealthbox. I can always pull the 13w3v3 that's in it and change it out if needed.
It looks like it's screwed into the frame at the bottom (near the left corner), and at the top into the foam holder for the tire pump and fuel funnel (Brembo kit flat solution ) As for bracing, I don't see anything else, but it could be underneath.
Looks like a very nice install. I wish I knew anything about audio to start my own build list but one thing at a time I guess. Getting my tablet to work perfect, followed by tires (have my rims already), then exhaust....God the list is endless. LOVE the car BTY.
Matthew
Matthew
If you drive a GT500 and are worried about having too much weight in your car you are a little clueless. I like the install. That box is very well done. I would've used different stuff though.
Diode Dynamics
6/12/18 03:26 PM
