-   '10-14 Interior and Audio (https://themustangsource.com/forums/f803/)
-   -   Changing OEM seats to racing seats (https://themustangsource.com/forums/f803/changing-oem-seats-racing-seats-541259/)
redonblackpony Apr 27, 2016 06:31 PM
For those of you who have removed factory seats in place of racing seats and harnesses, what can be done to clear the seatbelt light and airbag light?
I've heard that removing the fuse will take care of the light but it also disarms the two front airbags.
What are some alternative options?
Thanks for any suggestions
houtex Apr 27, 2016 08:38 PM
The seats in a late 2007 and up Mustang are integrated with the airbag system. You cannot remove those and have the airbags work. Ditto the seat belts. They are all part of the bigger SRS system, and if any of them are not connected to their yellow (last I checked) connectors, the entire system isn't going to work, hence the lights.
Which is why the fuse is pulled, because it'll never work without all the components working and connected.
Only alternative is to hook up the raw seat mounted airbag out of the original seats, and stuff it under the seat... but I really wouldn't do that. ;)
SGwick Apr 28, 2016 04:54 AM
Originally Posted by redonblackpony (Post 6979011)
For those of you who have removed factory seats in place of racing seats and harnesses, what can be done to clear the seatbelt light and airbag light? I've heard that removing the fuse will take care of the light but it also disarms the two front airbags. What are some alternative options? Thanks for any suggestions
not sure if it was this forum or the "other recommended by dmicheals" that I read but it can be done. I vaguely remember not doing it yet because it involves creating something like a "dummy load" using resistors and using the factory connectors underneath the seat
dmichaels Apr 28, 2016 09:07 AM
Seatbelt light is easy. Look up the process in your owners manual! It's there. I did it
The airbag is more difficult. You need to wire in an equivalent resistor if I remember correctly. My friend John did it in his Boss. There might be a "kit" out there. Check the other forum as it's definitely discussed there
Jazzman442 Apr 28, 2016 09:21 AM
If you order the Ford Racing Recaros, or get the Recaros out of another Mustang will this still be an issue?
dmichaels Apr 28, 2016 10:31 AM
Should not be a problem cause those are airbag friendly per my understanding. OEM equipment on track pack cars
redonblackpony Apr 28, 2016 10:46 AM
I will definitely investigate this on the 'other' forum. I remember reading somewhere in the past about a resistor.
Thanks for the info
I'll have to check out my manual from Ford.
Definitely will be ordering seats and harnesses by tomorrow
Glenn Apr 28, 2016 01:33 PM
Just put a piece of elec tape over the dash light.
Kotenukimen Apr 28, 2016 01:56 PM
:rofl2::lol::rofl2:
redonblackpony Apr 28, 2016 10:00 PM
That is an option. 😆
07MRMIKE Apr 29, 2016 03:33 AM
I went with the black tape route, hehe
But if you want to do it right you will need ford part # XF2Z 14022 AA but you will need to bring the resistor down to 2 ohms which means cutting open the connector taking out resistor and soldering in 2 ohm resistor.
Mike
PJRManagement Apr 29, 2016 10:43 AM
I swap in a racing seat for track days. I have it welded to a Ford OEM manual seat frame. It came with seatbelt receptor and wire harness with clip. No seatbelt light issues. This does not solve the airbag issue, though. Here's my thread on TMS for this: https://themustangsource.com/forums/...-my-gt-519126/
redonblackpony Apr 29, 2016 01:05 PM
I definitely like options.
Thanks for the input
