Anyone know of any currently available trunk lid organizers -- in particular ones that you can attach to the underside of the trunk lid.
I'd like one to store items like a few tools, jumper cables, etc. and I don't like those things flopping around in the trunk when I drive (and they won't fit in the spare tire area).
The Roush Install PDF at Your Link Might Be Useful in Planning an Install. Not Sure How Much Weight Would Play into Trunk Lid Staying Up or Not. May Also Need Some Cables Similar to Hood Pin Cables if You Wanted it To Open Like a Bench Position.
Anyhoo Just My two Cents For Some brain Storming If You Can't Find a Plug & Play version. Wonder if ROUSH Would Just Sell You a Case Less Contents??? Maybe Worth a Call. Perhaps You Could Find Manufacturer That Makes Them For Roush If They Were Unable to Help!
There are water-tight cases I believe made by Pelican and they come with foam you can cut for whatever you wish to store in them. I had one for tools when I had my Morgan. You can see it just to the right of the rod that holds up the bonnet.
