Aftermarket amp install
Old Nov 22, 2015 | 12:45 PM
Grabber5.00's Avatar
I installed the factory nav system so I need to go with an aftermarket amp. From what I can tell the factory amp for the door subs is still used so I need to power the four speakers between the doors and rear deck. Can I use this PAC AOEM-FRD24 to splice into without hacking up my factory wiring? Or did anyone who wired in a aftermarket amp have any suggestions? Was headed to the stereo shop but 14" of snow on Friday brought that to a halt. Thanks.
Old Nov 22, 2015 | 08:23 PM
DJ2014's Avatar
This is exactly what I used. I installed an eq and amp to improve the sound. Also replaced all four speakers and ran new speaker wire. That was a pain getting it through to the door speakers. I left the door subs being powered by the oem amp. I would love to install the factory nav system. Was it an easy install?
Old Nov 22, 2015 | 08:31 PM
The install on the factory nav wasn't hard. Just time consuming. It really is just plug and play though right up to this part. Why did you run new wires to your speakers? That is what I am hoping to avoid doing by using this PAC module.
Old Nov 24, 2015 | 03:45 AM
DJ2014's Avatar
I could have just spliced into the factory wiring but it was easier to run new wires.
Old Nov 24, 2015 | 05:56 AM
Phillip123's Avatar
It's very easy to install.
Old Nov 29, 2015 | 04:38 PM
I am apparently finding the amp install tougher than most. I used the pac module I listed above but I only got the right front and right rear speakers to get any sound. I tried switching those leads to the front left and rear and still no sound? Then I took out the RCA leads and wired it speaker level and just used the pac harness to splice into. Same results When I look at the wiring diagram it appears that the pac module is pinned correctly. Any one have any ideas what I am missing?
Old Nov 29, 2015 | 05:50 PM
Blue Notch's Avatar
I think there's some little holes on the module where you can adjust the signal level. I did mine over a year ago so I can't remember all that well.
Old Nov 29, 2015 | 06:01 PM
I see there are holes above each channel that looks like you can adjust stuff. But I am not getting anything to the drivers side of the car. Did you have to adjust those to get your signal?
Old Nov 29, 2015 | 06:58 PM
Blue Notch's Avatar
I might have. I sort of recall having an issue and googling it but like I said, that was over a year ago. And just to rule out the simple stuff, you have the balance and fader set to the middle, correct?
Old Nov 29, 2015 | 07:08 PM
Yeah. Fader and balance are set correctly. The other weird thing is that the outputs that do work don't match up to the fader and balance. I have both the front and rear right side going but it's like they are both running off the front signals. When I fade to the rear I have nothing. Like the RR is running off what should be Front left. Factory wiring diagram looks like what I have on the aftermarket harness should be matched up correctly though. I don't know what the hell I'm doing wrong.
Old Nov 29, 2015 | 07:27 PM
Blue Notch's Avatar
If you swap the RCAs does the sound move to the other side?
Old Nov 29, 2015 | 07:31 PM
I swapped the wire leads and the sound did not move over. I hacked the rca's off and direct wired it and switched the amp to speaker input and no change.
Old Nov 29, 2015 | 07:34 PM
I thought that maybe the acm was bad but I should have sound when I switch the wires.
Old Nov 29, 2015 | 07:57 PM
Blue Notch's Avatar
That's weird.
Old Nov 29, 2015 | 08:04 PM
Did you run new wires or just use the pac module?
Old Nov 29, 2015 | 09:32 PM
Blue Notch's Avatar
I hooked up the PAC to the stock head unit then ran RCAs to the amp in my trunk. I also ran new wires from the amp to the aftermarket speakers.
Cavero
Sep 21, 2023 07:45 AM
Jazzman442
'10-14 Interior and Audio
Jan 21, 2016 08:02 AM
jonser
Nov 20, 2015 01:45 PM
