'13-'14 Shaker amp wiring diagram?
Anyone have the wiring diagram for the Shaker amp on a 2013-2014? Ford changed the amp for 2013 (confirmed by looking above the driver kick panel) and supposedly the wiring, as well. I'm looking to tap into the outputs to the door woofers but don't want to run cable to the doors. Everything I found so far has been for a 2012 or older, or a base 2013-2014.
Thanks.
Thanks.
After some sleuthing by tracing the wires from the door woofer back to the amp, the wiring colors are the same, just the amp is different. For '13-'14, the I/O harnesses connect on the same side of the amp, towards the firewall. Folks with large hands will find it a biotch to undo the output harness.
