Tire size for staggered tims
I currently run 20x8.5 and 20x10 rims with nitto invos which are 255-35-20 and 295-35-20. I love the look of the rears, and I was thinking about doing 275-35-20 in the front, but I'm worried about getting a muffin top look. I think a 275 would be too wide for an 8.5 rim. Does anyone currently run a 275 with a 8.5 inch rim? Also, do you think a 315 rear would be too wide for a 10 inch rim? I want to go as wide as possible without getting a side wall that spills over the rim. Thoughts?
I think 275 would be too wide for an 8.5" rim, but you should be ok with 315's on a 10" rim.
I want to get a set of rims but the only thing I can find for Brembo that I like is in 8.5 and 10 inch sizes. I'm good with 255's on all 4's, so going 10's in the back is not a big deal for me. Anyways, I always thought 255's would be too much for a 8.5" rim and since you have them I'd appreciate it if you would post a picture of it, and include any thoughts you might have. Thanks
You sure those aren't 9'' wheels? I've also heard that Nitto's run narrow but is that a Nitto you have?
I have 255 on 8.5 in wheel and it looks a little wider than that. Not a huge amount but def wider. These are a private label brand tire that I got from the wheel dealer.
