New hood, how to paint
if they can't match the paint perfectly then they will have to blend. I went to 4 places recently for estimates to have my hood painted and all 4 said they would have to blend. 6 yr old paint tho.
You probably won't have to blend on a brand new car, especially Race Red since it's non metallic. You really only need to blend on metallic/pearl/faded paint, as Glenn suggested.
Originally Posted by Glenn
my quotes were 800 for both sides and 400 for one side. Lots of block sanding. its a new piece not something that just has to be repainted.
#1. What hod did you get and who did you get it from? Reason I asked is cause Cervinis puts a really nice gel coat on their hoods which bodyshop love cause it makes prepping easier.
#2. Are you planning on painting the top and bottom!? When I had my CobraR hood painted form Cervinis the gel coat was a gloss white which almost matched the stock white perfect, so I only had the body shop paint the top and left the bottom gel coat!
I paid $430 to have mine painted on both sides. They didn't have to blend, they color matched it perfectly. Paint on hood is better than factory! Owner did cut me a break on the price since we are both car enthusiasts; I drive a GT500 and my wife has a Roush, he drives a ZR1 and his wife has a ZL1.
Originally Posted by mikeyt03
It's the trufiber hood in this pic but its fiberglass. It's got a gel coat over it, but my car is red so It might look weird to leave the underside un painted.
Originally Posted by Planeswalker
Be sure to test fit it before painting it!!!!!! I didn't test fit my Steeda hood and ended up regretting it. Also, be sure the gel coat is/has been properly cured, didn't do this with my Steeda hood so the shop had to redo the whole hood.
You mean baking it right? Yeah I will test fit it first thing. I don't want any crazy gaps to deal with. I hope I can get my price down to 430, that's pretty reasonable.
cervini's states 5 days in the sun or bake at 140 degrees for one hour. I called them and told the the weather wasn't all that warm around here. He stated just leave it in the sun longer then. The heat from the engine helps too. I drove with the hood on for at least 7 days plus I had it in a oven at 125 degrees for about 2.5 hours.
