gt/cs hid fog lights not working
Old Sep 8, 2014 | 07:38 PM
rockpolisher's Avatar
I installed a hid conversion kit 35w 4300k for the lower fog lights but when I leave the auto headlight and fog light switch to the on position and start the car, only one side of the fog lights turn on. If I push the fog light switch on and off a couple of times then both will work. If I turn the car off and then restart the car right away with head lights and fog lights in the auto position, it will all light up. However, if I turn the car off and restart the car an hour or so later, it does the same thing again where only one side of the fog lights turn on. Any ideas?
Old Sep 8, 2014 | 09:07 PM
Blown CS's Avatar
I am having the same issue with my CS hid's and it is due to the low volts from the auto on lights. Thinking about running a relay and their own power source.
Old Sep 9, 2014 | 12:05 AM
Wouldn't the relays that came with the hid kit be sufficient enough?
Old Sep 9, 2014 | 06:22 PM
Siber Express's Avatar
Voltage draw from the starter is not letting the HID get enough voltage to start. The Headlamps work of a circuit that is not keyed so they fire right off where the fogs are keyed thus losing voltage when the starter engages.
Old Sep 9, 2014 | 10:41 PM
Thanks guys. I guess it's not that hard to pull the fog light switch manually.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
defiance772
Oct 21, 2015 09:37 AM
Earlsays
Aug 5, 2015 07:10 AM
