Front mud flaps?
Front mud flaps?
Seen these as well as a few others, thinking I might go with these, unless Ford makes an OEM one for the GT500 that will work on a GT like the rears that are now standard on the GT from the factory?
http://www.americanmuscle.com/front-...ards-1012.html
The sticky tires throw stuff at my rockers constantly and it makes me cringe so bad…after every drive i bust out my iPhone and use the flashlight to inspect behind the front wheels for rock chips lol…but god i hate mud flaps (though the rears don't bother me whatsoever since it came that way from the factory, go figure)
I'm concerned about the fact this is a year round daily, so salt will get stuck between them and the metal fender lip where I can't wash/wax…and once they are installed I don't want to be pulling the clips out over and over to remove them to clean behind them since then the clips will get loose and crappy. thoughts?
I'd say get them....they aren't even noticeable on my car and I don't have any issues with anything getting caught between them and the inner fender. Here's my story I posted in another thread....
A 2 mile stretch of road with loose gravel/asphalt that had been routed out for center line reflectors a few hours earlier left small chips and abrasions on my lower door and rocker panel. The next day I ordered these as I think they would have helped minimize the damage.
Hope this helps.
Let me know if you have any questions or need some assistance in the near future.
-Dan
The rockers on these cars definitely take a beating. The rear section of the car is usually pretty protected with the factory mud flap. However, the side rockers really get hammered with rocks and road grime. If the car is a daily driver, I highly recommend picking up a set of Mud flaps. The attached mud flaps aren't big and bulky so they're pretty sleek. They'll definitely do the job though!
Hope this helps.
-Dan
Hope this helps.
-Dan
Roush splitters do the same thing. I'm just not feeling front flaps no matter how inconspicuous.
I have the same guards you ordered I think they are working great they don't look bad either. My next exterior mod will probably be the Roush side splitters and rear splitters.
Edit: I also drive about 2 an a 1/2 miles of gravel road every day one way.
PM'ed back!
-Dan
It should definitely help! I'm getting ready to install a set of my car also. The roads are not very pretty this time of year. Good luck with them! Let us know if you have any feedback.
-Dan
-Dan
-Dan
I've had mine on for a while. They're so inconspicuous you don't even notice them. I can report that they do help, but I've still got additional wear on my rocker panels since I put them on. Granted, this was a brutal winter and PennDOT mixing in gravel with their salt surely didn't help.
Thanks guys, hoping my flaps arrive today or tomorrow. Indeed the roads are pure trash up here in the north, aside from the potholes are the trillions and trillions of stones/rocks in the road that came out of the potholes...even when they go around and have crews fill the potholes with a shovel and a truck full of tar, they don't bother to sweep up the extra so even when there is a filled pothole, there are even more rocks on the road, ughhhh
hurry up and sweep the streets already...
I just installed my flaps from AM. Pretty happy with the final install, probably the best flaps out there for 2010-2014 Stangs.
Taking out the clips was easier than expected, probably due to the car being so new and the clips not being all crusty. I found that the innermost/lower clip snapped right back into place nicely with the flap installed, but I had problems getting the outermost/upper clips to clip all the way back in once the flap was installed. I could tell they weren't going anywhere, but I could also tell that they weren't snapped all the way in like the lower ones. It took several attempts and messing around with it, but eventually I got the upper clips to snap in nice and tight…I found that using one hand to push up on the rocker panel and the other hand with the clip to push in around where the upper hole was while installing the clip did the trick. Probably took 30 minutes total given that I had to mess with the upper clips.
Not a huge fan of the shiny fronts, but I suppose that's for cleaning? I'd still rather see the fronts be textured, or at least not shiny. Would also be nice if the texture on the backs matched the texture of the OEM rear flaps, but oh well.
I have the flat - curvable mud flaps with the running pony on them. They are a Ford accessory. The nice part about them is you can mount them at whatever height you want. I just use the rocker panel front push pins to mount them.
