Biggest tire that will fit on standard 18" rim??
Old Mar 9, 2011 | 05:36 PM
2012GT's Avatar
My GT is coming with the standard 235 series tires on the standard 18" rims. What is the widest tire that will fit on that rim and still make a good contact patch? thanks
Old Mar 9, 2011 | 06:48 PM
karman's Avatar
Cool
Personally on an 8" that is as big as I would go.
I know you can go bigger (you can do a lot of things), but I would use larger rims.
Old Mar 9, 2011 | 09:31 PM
Siber Express's Avatar
255/45 18 will go, 8.0 is the minimum size rim according to Toyo
Old Mar 9, 2011 | 10:09 PM
2012GT's Avatar
no drag radials offered in that size from what i've seen. No options for drag radials yet with a 18x8 rim?
Old Mar 10, 2011 | 03:38 AM
But you do have a 10 inch wide wheel that matches the OEM wheels for Drag Slicks available http://www.americanmuscle.com/silver...8x10-0511.html
Old Mar 10, 2011 | 07:19 AM
2012GT's Avatar
Nice looking rims (the chrome looks sweet). Are they the same weight as stock, more, less?
Old Mar 10, 2011 | 11:34 AM
Timeless's Avatar
If you go with a pair of these for the rear to get bigger tires, will having 235s up front affect anything?
I guess if I have stock 235s up front, is there a limit or best combination for the rears? 275 or 285? Is is a 10" rim option for the back.
Old Mar 10, 2011 | 02:44 PM
Not sure about weight, but the fact that you gat more traction it would probably be worth more than you would loose for a few extra pounds
Since there are cars running Pizza cutters on the front with DOT Slicks on the back I think you would be fine with the 235's on the front.
I myself would go with the 285/40 18's. Those 10 inch wheels from AM say Fits Rear Only.
Old Mar 13, 2011 | 04:54 AM
2012GT's Avatar
They have 18x9's for the front and 18x10's for the rear. The offsets are different too so that the bigger tires on the rear won't stick out. I know a guy with an 06 GT and the aftermarket rims look like **** because the tires stick out about 2 inches on the rear due to the offset being way off.
MRGTX
Jul 21, 2015 02:08 PM
