2011 Mustang GT and Window/Tailight/3rd Brakelight Tint and Flowmaster Hushpowers
Bought my 5.0 right before Thanksgiving and have done the following:
20% Tint on all windows (except windshield)
Smoked Tailight and 3rd Brake Light Tint
Flowmaster Hushpower Axlebacks
Steps I used:
- Clean tailights with a solution of warm water and 3 drops of baby shampoo.
- Use blow dryer to heat vinyl, which makes it easier to stretch b/c the tint won't be perfect.
- Unpeal tint from backing and spray back of vinyl and tailight with soapy solution.
- Position vinyl over tailight as best as possible.
- I had my wife constantly use the blow dryer to keep the vinyl warm and stretchable while I pushed all the solution out from under the tint using the included squegee and stretching it to the edges of the tailight tint.
- If you have bubbles still in there after you finish, they should disappear after sitting in the sun for a couple of days (a little longer if it's cold outside)
It's not that hard and if you mess up and hate it, you can always pull it off.
Looks great!!
Now you gotta get those ugly red and yellow sidemarkers changed over to clear or smoke or black.
Check out this groupbuy that Overboost is working on here
Love the look of the tinted taillights. But I am always worried about the how legal it is. All I need is some asshat to rearend me on the highway. And have them sue me for having tinted lights and claiming its my fault.
Best way to do this is wait until night and take a flash camera the specified distance away and shoot the rear. If the reflector lights up you should be legal.
But, definitely check first, I'm sure each state is different.
http://law.onecle.com/new-york/vehic...T0375_375.html
3. if manufactured on or after January first, nineteen hundred
fifty-two, at least two lighted lamps on the rear, one on each side,
which lamps shall display a red light visible from the rear for a
distance of at least one thousand feet; and
4. if required to display a number plate on the rear, a white light
which shall illuminate the numerals on such plate in such manner as to
render such numerals legible for at least fifty feet from the rear. The
provisions of this subparagraph shall also apply to trailers.
So as long as your tail lamps are visible at night from a distance of 1000 feet, you are fine. I believe this refers to the running lamp as opposed to the brake lights.
Thanks.
I wonder if someone has tested how far back these can be seen.
I guess the worst case would be to buy it and if it does pass just take it off.
Maybe the OP wouldnt mind doing a test to see if it works?
Thanks again.
Thanks again.
Yeah, I have stangmods custom cutting some for my front ambers since they don't have any yet and will be getting the ones for the rear too. Can't wait...it should like nice. Now I just need to darken the wheels a bit (I wish they came more of a gunmetal/anthracite color, than bright silver)
Just got the tint for the front side markers from stangmods...they sent me smoked tint, but you can see the amber color in the daylight, so I would go black-out for these. I'm going to see if they can send me some black out for both front and rear side markers.
MRGTX
Jul 21, 2015 02:08 PM
AMWill
Jul 16, 2015 04:26 PM
