Throttle response delay
Is there any way other than a tune to eliminate the throttle response delay in a 2014 V6? I love my Mustang, but would really like to have the instant response that I get in my 2006 Honda Accord V6. However, I don't want to go with a tune and jeopardize my warranty. Any options?
It's hard to say what the proper fix is without knowing exactly what the cause is. Is the issue that the transmission doesn't down shift quickly enough when you put your foot down or is it that when you are already in the powerband that pressing the accelerator has a significant delay before acceleration?
The best example I can give you is that when I floor it off the line, there is a delay before the revs start to climb rapidly. The same sort of delay occurs when I'm driving along and come to a place where the speed limit increases (say from 30 to 35) and I press down on the pedal to accelerate in the same gear. Another good example is in autocross when I am using SelectShift and am in second gear and come around a turnaround and floor it headed for the timing sensors. The transmission can't downshift in that situation, but there is again that brief delay before full acceleration.
Thanks, guys. I figured it was the ECU that was the culprit. Guess I'll just have to wait until my warranty is up and live with it in the meantime.
Please consider this thread closed.
How can they refuse it? I've had warranty work done on my clearly modded car, from the ticking noise, the belt squeal and the power seat motor. They can see when a motor has been abused. I also let the dealer do almost all my maintenance, so they know I'm not screwing the car up and then trying to make a warranty claim. They can see my service record in oasis.
Please bring this up to your dealer and have them check it out. Then, PM me with your dealer, mileage, full name, and best daytime number so I can escalate this to the customer service manager for your area.
Also, Ford Racing Parts come with their own warranty and if your dealer is a FRPP dealer, they will only honor those aftermarket mods. You can locate one of our FRPP authorized dealers here.
Deysha
I went in and met with the service manager today and we went for a ride so I could demonstrate the throttle response delay. I've made an appointment to take the car back in so they can hook up a laptop and do some testing and record some data during a test drive. They'll also see what version of software is installed and whether or not there have been any more recent releases.
They may tell me that is the way it is and there is nothing that can be done about it, but at least that was not the up front position. I'll update this thread after my service appointment.
i think they will just tell you its how it is. i never noticed a more slower than most cars throttle response on mine but mine is a m6 so that might make a difference although i did notice a huge improvement in throttle response when i tuned mine. so much actually that i had to get use to it in order to take off smoothly since mines a m6.
They may do that. The service manager did take a tech with a laptop and recorded data that they are sending to Ford engineers. I'm willing to do it Ford's way and see what answer I get before I ask my service manager about tunes and warranties.
I 'think' all newer cars are done this way because, too many old people (i'm one
) were pressing the gas pedal instead of the brake pedal. The delay gives a little bit of time for the person to realize they have messed up
i never knew that anybody had that problem.
, my tunes have the throttle delay removed. I have seen and read a lot of old people through the years on the local news and newspapers hitting buildings and other things with their cars
Hey Tukatz, ive got the same issue with my 13 v6. My dealer is going to custom tune it for me. I asked about warranty . They stated that they have done it before. Also, the dealer would have to prove that the custom tune was responsible for the warranty problem, so...
Interesting. My dealer took a new V6 auto out and felt that it had better response than mine. They are going to flash mine back to factory spec and see what that does. The latest theory is that my engine computer is learning from my driving style - I guess I don't thrash it enough. I'll be sure to ask them about a tune. It goes in next Wednesday.
I took her into the dealership today and they found that there was a newer version of software that was released recently, so they flashed that to the computer. It's wet out today so I haven't been able to do much testing, but my initial reaction is that she is more responsive.
1.Turn on car without starting the engine
2. Wait until the dashlights stabilize (some of them will turn off)
3. Step on the gaspedal in one smooth and steady motion
4. Once gas pedal hits thebottom, let go
5. Turn off car and wait 5+ seconds
6. Turnengine on
7. Drive
8. Repeat 1-6 if it doesn't work the firsttime.
