Looking for a REAL WORLD 1" drop for my DD
I am putting together my suspension build and am looking at the Steeda Sports but I am afraid they will not drops as much as advertised ( 1" front/ 1.25" rear). I currently have 20's and the car is my DD so I do not want more of a drop than an inch. Can anyone confirm or deny the actual ride height/drop of the Sports on a V6?
Thanks,
Matthew
Thanks,
Matthew
Thanks,
Matthew
Thanks,
Matthew
I was trying to do the same but after talking to TJ and Matt from Steeda yhey are noy recommending any if there springs for us V6 guys because it won't drop correctly. They were telling me that it would actually make it so the back sits lower than the front because the engine is so much lighter. The thing is that on there website it only says not to use the sport springs but it doesn't say we can't use the ultralites (I wouldn't risk it). They are developing a spring specifically for the V6. If you are looking to do it now I woyld go with the Eibach pro-kit. Had it on my '12 V6 and I loved how well they helped the handling and the ride. My only complaint was that it didn't drop low enough for me so this time I will probably go with the sportlines. Pro-kit drop is .8 front and 1.2 rear.
Can I see pics of your other car with the Eibach pro kit? and also pics of your new car with the sportlines once you get 'em... Ive been thinking about going with one of these but was hoping to see some clear shots of the drop before
This is the only pic I have from the side of my '12 V6. I won't have the sportlines on the '14 until spring.
Do you remember the size of those wheels/rims/tires?
Also, do you temember if when you took this pic, had the springs already settled in or were they just barely installed?
The wheels & tires are stock that come with MCA pkg. 18x8 I believe and tires 235/50/18 all around. This pics was after they had settled. Just after install the drop was almost as advertised ( .7 front & 1.15 rear) but a couple months later the front drop was 1" and rear was 1.2. Also I didn't have a spare tire in the trunk, I had that tire mobility crap that Ford was putting in the Stangs. Glad this time I have a actual spare.
EDIT: nevermind, entered wrong info for my tires lol. Mine are actually 27" so were about the same. Question remains about the sportlines tho. Have you ever seen any in person?
I like that. I might go with that one, I don't want a huge drop because NoVa roads suck but I do want it a little lower
I have not had any issues here in South Florida with clearance. Never once hit the undercarriage and I can barely clear a front parking block. My bump stops hit the back occasionally, I am thinking of cutting of a notch.
Ford Racing V6 Handling Pack
![](http://i148.photobucket.com/albums/s12/ustabawannab/Mustang/Front_zps3d4c9acc.jpg)
Just a teeny bit higher in the back. I love it. Well designed specifically for the V6
http://www.hotpart.com/2005-2011-for...t-your-option/
Sorry guys been away for a few days due to work. THANKS for all the input.
How is the ride on the Eibach's? I have heard it is a harder ride then the Steedas and being it is my DD I dont want a harsh ride. Thats what my '95 is for.
How long ago did you talk to Steeda? I wanted to get the parts (PHB, springs, CC plates) from the same place and Steeda has a great rep. plus all of their parts are made in the USA (<-- big selling point for me).
That looks good and it ended up being a 1/1.2 drop like you say that would be exactly what I am looking for!
What is wrong with the mobility kit? I was actually thinking of buying one as I have '20s so the spare would be less that useless to me and the mobility kit would cut down on weight.
I have never heard of Vogtland before. Do you know who makes them? I am planning on going with Koni's, how are they ride wise? Hard, soft, or stock feeling?
Thanks but 1.5 is to much for me. Having the CS lower valance I cant drop more than 1''.
I was looking at that kit but its so expensive. What was the overall drop?
Thanks. Ill look into it.
Matthew
I was trying to do the same but after talking to TJ and Matt from Steeda they are not recommending any if there springs for us V6 guys because it won't drop correctly. They were telling me that it would actually make it so the back sits lower than the front because the engine is so much lighter. The thing is that on there website it only says not to use the sport springs but it doesn't say we can't use the ultralites (I wouldn't risk it). They are developing a spring specifically for the V6. If you are looking to do it now I would go with the Eibach pro-kit. Had it on my '12 V6 and I loved how well they helped the handling and the ride. My only complaint was that it didn't drop low enough for me so this time I will probably go with the sportlines. Pro-kit drop is .8 front and 1.2 rear.
J+M has them listed up to 11, I would say they will fit a 12-14 also.
Matthew
Matt, there is nothing wrong with the tire mobikity kit, I just prefer having a actual spare as the mobility kit has those canisters that you have to replace once you use it and if you have a bad enough blow out you can't use it anyway. I talked to Steeda about a month ago. Nothing has changed from when I talked to them and they didn't seem to know when they would have a spring out for the V6. You can contact them on here for full details. I also just found out that 13 & 14 MY are 55 lbs. heavier than 11-12 MY so the Eibach might be slightly lower on yours than my '12 but not much. The ride was not bad at all just a little stiffer and much better handling. I had them installed with stock shocks and struts tho so if you change those to I think your ride will be good and handling great!
Matt, Vogtland Springs are made by Vogtland, they do manufacture springs for others though. http://www.vogtland-na.com/en/company.php
I was running them with SRT.T Koni's and the ride was almost as good as stock. When I do suspension on the 13 I will be getting Koni Yellows though, I would like to firm up the Shocks when I go to the Mountains.
