Sponsored by:
Sponsored by:
TSW Nurburgring 18x9.5
Old Apr 14, 2015 | 03:07 PM
konastang21's Avatar
Looking to buy 18x9.5 tsw nurburgrings gunmetal or maybe 18x9. I have brembo brakes does anyone run these on 18's. What offset are you using and wat tire size. How does it fit the brembos
Old Apr 16, 2015 | 06:49 AM
Dean Martin's Avatar
All I can offer is that I have them as 19 x 9.5's with 41mm offset and 275/40-19's with no clearance issues. Mine is not a Brembo car but everything I read said they would clear.
One issue they do have is that the front center caps don't clear the dust cover and won't pop in correctly. I changed to a different cap anyway but it took a bit of time to find a fit.
Old Apr 16, 2015 | 04:35 PM
Springer200's Avatar
Exactly what I have - 19 x 9.5, and 275/40's, and mine is a Track Pack car (Brembo's).
No rubbing, no issues, I love them.
On the front centercaps, I "clearanced" them with a grinder (A Dremel would also work). I removed material from the inside of the centercap until they fit.
Interestingly, the centercaps will not interchange - one centercap had to have much more material removed - basically everything except the outer ring of plastic, and then I re-taped the metal centercap to it (and probably the Ford dustcap).
I read on a thread somewhere that the hub thickness can vary on that wheel, making the centercap fitment weird. I was thinking of rotating the tires, and this reminds me that I will have to swap centercaps, as well. That's the price for style... LOL
FYI - My car came with 19's stock, and I assume that is for fitment around the brakes. I would be careful downsizing the rim.
Old Apr 16, 2015 | 06:41 PM
I used factory tri bar running pony caps, wrapped in a few layers of friction tape around the OD to tighten them up. They look great, been in for over a year. Stay nice and tight but easy to remove for balancing etc. And easily clear the dust caps....
Old May 6, 2015 | 12:44 AM
Burke985's Avatar
I had a set of 19" and they fit fine , I don't think they would work with brembos on an 18" rim
Old May 15, 2015 | 12:36 PM
hvysoul's Avatar
Which center cap did you go with as a replacement? And where did you source this cap? I have these wheels in 19x9.5 square and would love to have center caps that fit and are not "engineered"
Old May 17, 2015 | 05:28 PM
Try part number 8R3Z-1130-A on EBAY. They are the OEM factory item for like 2005 - 2009 cars.
I remember I used a dremel to grind down some nubs so they would fit flush, and again a few wraps with friction tape to make them very snug.
Been a year plus so I don't remember all of the details....but have not lost one and they look awesome. Good luck, but they are kind of "engineered".
Old May 21, 2015 | 02:22 PM
Brandon302's Avatar
OP I run 18x10 +35 Team Dynamics rims with 295's on all corners and have no rubbing issues so something similar in 9.5 or 9 should be fine.
Old May 31, 2015 | 01:18 PM
Fords4Ever's Avatar
I would like to see what that looks like, do you have any pics?
Old Jun 1, 2015 | 01:04 AM
No rubbing, no issues. Ford Racing springs
Old Jun 1, 2015 | 11:52 AM
Here you go....
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
SaleenPowr
05-09 Exterior Modifications
32
Feb 27, 2006 12:35 PM
markski74
Apr 7, 2005 12:28 AM
NosferatuVI
17
Jan 4, 2005 04:16 PM
