Notices
Tires with SVT TP wheels
Old 11/1/10, 04:55 PM
montreal ponies's Avatar
Will be getting the 19" SVT PP wheels shortly and was wondering what size tires to go with. I'm keeping the Continental DW extreme 255/40's for the front. Running 275/40's rear with RTR wheels right now. Since the offset of the RTR's is 31, i cannot keep those tires with the new Ford wheels which have an offset of 51. Trying to get some more rubber out back. Looked at a few different applications like going with 285/35's which keeps me in spec with diameter and sidewall height but not wide enough to my taste. Thing is i want to get 295/35's but they are not available with Continental tires and very hard to come by in that size with most tires manufacturers. Of course i don't want to have to change all four tires, so i'm wondering if anybody has one of the above tire size set up installed on his 'Stang and could provide specifically some rear photos of the rear tires. I'm concerned that with 285/35's, it won't fill in the wheelwell properly. That's why i badly need some pics of actual member's car.
Thx guys.
Old 11/1/10, 05:09 PM
m4reapr's Avatar
why not the Conti's you have now in the 305/30/19 size
you're going to have a 10 inch rim so it should fit fine, 285's on a 10 inch rim look too narrow
you have the tuner to compensate for the small difference in circumference, ~3% smaller
$270 from tirerack
Old 11/1/10, 05:32 PM
Swamp Donkey Aficionado
MARZ's Avatar
Where'd you purchase the wheels? I can't wait to see these on your car!
Old 11/1/10, 06:34 PM
Ltngdrvr's Avatar
Thx guys.
Having a litle bit of a hard time following this.
You are getting 4 SVTPP front wheels as those are the 19" size?
Why is it that you say the 275/40's won't work on the rear? The different offset shouldn't make any difference to that.
The other question is, if you have 19x9.5 RTR's now, why change to the SVTPP wheels?
Old 11/1/10, 06:43 PM
MARZ's Avatar
Actually, the SVT PP wheels offered through Ford Racing aren't exactly the same wheels available on the GT500. The aftermarket wheels are available in 19x9" front and 19x10" rear.
http://www.fordracingparts.com/parts...KeyField=12305
http://www.fordracingparts.com/parts...KeyField=12304
Why does it matter why he's changing his wheels? Perhaps he prefers the design of the SVT PP wheels? Perhaps he's after a wheel with the correct rear offset, thus eliminating the "stuck out too far" look of the RTR rear wheels?
Old 11/1/10, 07:13 PM
$270 from tirerack
I taught about going the 305/30 route, but figured the tire height would visually impact too much the front tires which are 40's, unless someone can show me otherwise with a pic.
Here is a site i found: i'm more than 3% in diameter too fast. I'm most worried about looks than revs per mile which i can adjust with my XCT3 programmer.
http://www.1010tires.com/TireSizeCal...?action=submit
Old 11/1/10, 07:20 PM
Yep, that is exactly why i'm changing them to the SVT PP wheels, i want more offset so i can fit bigger tires in the back. The widest you can go with RTR's in the rear without rubbing the fenders is 275/40's. At first i liked it, but not exactly the look i taught it would give. Still, they're nice wheels, but the offset is starting to annoy me a bit. Getting very good deal on 4 FRPP 19" wheels.
Old 11/1/10, 07:45 PM
Don't know about the 285's that are on the Shelby GT500 with PP.
(265/40R-19 front, 285/35-20 rear.)
Old 11/1/10, 10:26 PM
Ltngdrvr's Avatar
Well, in a 19" tire, the 285/35/19 is the only tire that will maintain the correct height compared with the 255/40 front, a 305/30/19 is enough shorter that you could tell the difference between them pretty readily.
Old 11/2/10, 03:22 PM
Unless i go down to 255/35/19 for the front.
Stock Tire - 255/35R19 >Search Tires Tire 1 - 305/30R19 >Search Tires Section Width:10.03 in255 mmSection Width:12.00 in305 mmRim Diameter:19 in482.6 mmRim Diameter:19 in482.6 mmRim Width Range:9.5 - 10 inRim Width Range:10.5 - 11.5 inOverall Diameter:26.02 in660.90 mmOverall Diameter:26.20 in665.48 mmSidewall Height:3.51 in89.154 mmSidewall Height:3.60 in91.44 mmRadius:13.01 in330.45 mmRadius:13.10 in332.74 mmCircumference:81.74 in2076.1 mmCircumference:82.30 in2090.4 mmRevs per Mile:799.3Revs per Mile:793.8Actual Speed:60 mph100 km/hSpeedometer1:59.5 mph99.3 km/hSpeedometer Difference: -Speedometer Difference: 0.692% too slowDiameter Difference: -Diameter Difference: 0.69%
Old 11/2/10, 03:55 PM
i3arracuda's Avatar
I'm looking at getting the same wheels, and I've settled on 255/40's in front and 285/35s in the rear. You could go to 265/35 on the front and 305/30 in the rear and have the same overall diameter.
Old 11/3/10, 02:43 PM
i think a 305 tire on a 10"wheel is too much, i would need at leat a 10.5 " wheel.
Old 11/3/10, 03:10 PM
i3arracuda's Avatar
Oop, you're right, 10" is pushing it a bit.
Old 11/3/10, 07:17 PM
Guess i'll have to settle for 285's then. I wanted wider in the back.
Old 11/3/10, 08:15 PM
StangFreak's Avatar
Thx guys.
A 295/35/19 would be perfect for your front 255/40/19's. Only tire a 295/35/19 is avail in is BFG's G-Force T/A KDW NT. If you want to stay with the Conti's you would need to run a 265/30/19 in front and the 295/30/19 in the rear. Either way you would need to purchase four new tires.
Old 11/3/10, 08:33 PM
Conti doesn't make such a tire in 295/30/19 in extreme contact DW model.
Old 11/3/10, 08:36 PM
Don't we all.
Old 11/4/10, 10:50 AM
StangFreak's Avatar
My mistake, I thought you had the DWS tire. They have the 295/30/19 in the Extreme Contact DWS.
Old 11/4/10, 12:38 PM
I am Shauny Clause
MOTM July 2010 Winner
Stinger1982's Avatar
Originally Posted by Stinger1982
2011 GT-500 Performance Pack Forged wheels
One one set available.
Front 19x9.5
Rear 20x9.5
Includes the new Goodyear F1 (actually a pretty badass tire)
The first $2,200 takes them
just saying
Old 11/4/10, 02:15 PM
That seems like a good deal, it's just the 20's that are bugging me.
Quick Reply: Tires with SVT TP wheels
