Sponsored by:
Sponsored by:
Switched power for PLX DM-100 gauge
Old Jun 23, 2016 | 12:35 PM
SwissGT's Avatar
I plan to install a PLX DM-100 touch gauge using the Roush vent mount. Seems like a fairly easy job to do, but the one thing I haven't been able to figure out is where to tap into switched +12V so that the gauge turns on and off with the ignition.
Any hints are most welcome.
EDIT: Sorry, probably wrong forum. Should be in '10-14 Interior and Audio, I guess.
Old Jun 23, 2016 | 12:40 PM
SpectreH's Avatar
The radio circuit is switched, maybe that can be located easily.
Old Jun 25, 2016 | 06:35 PM
Slowb00st's Avatar
There is switch power in the inside fuse box on the passenger side. You can use a tap a fuse, but be warned unless your skinny its a pita to get to it.
Old Jun 26, 2016 | 03:20 PM
SwissGT's Avatar
That's exactly what I ended up doing. The tap a fuse works great, except that the fuse cover cannot be put back on.
I used fuse 37, by the way. A spare one that is hot in start and run, exactly what I needed.
So far, the gauge works great.
Old Jul 1, 2016 | 04:39 AM
Slowb00st's Avatar
You had to get creative. I passed the two wires, since using two tap a fuses one switched other constant, through the vents in the fuse box cover and with the correct selection of fuses the cover fits fine.
M90CaliforniaSpecial
Jun 15, 2016 09:02 PM
chevellestang
1994-2004 V-8
Jun 8, 2016 02:41 PM
