-   5.0L GT Modifications (https://themustangsource.com/forums/f800/)
-   -   suspension question (https://themustangsource.com/forums/f800/suspension-question-495438/)
hireman May 16, 2011 01:06 PM
suspension question
I'm considering lowering my car on eibach sportlines ( I want it low) and using tokico d specs because of the adjustability and their reputation. Mostly street use but I drive fairly aggressive. I might also get into autocrossing the car every once in a while , cant see that becoming a every weekend thing however. Will d specs work well with sportlines? I have read where they work great with eibach pro kits but as you all know , sportlines are a bit lower...LOL!!
Glenn May 16, 2011 06:15 PM
I don't know for sure so I'm going to guess, yes they will work.
BlackMamba03 Aug 1, 2011 04:39 PM
as an agressive driver myself, id stick with eibach but id go with a coil-over system. gives you the ability to adjust to height manually at all 4 corners of the car. also id get some eibach adjustable sway bars to really give yourself a beast of a car.
